I run into classic problem of having to store long (way above 255 characters) text for use in UI (it is ChatGPT generated album description). For obvious reasons it cannot be stored as state. As ChatGPT integration provides response as content of call back event, it cannot be used as attribute in template (or I did not found any trace of how to make it due to lack of set_attribute service). So in many places people are pointing to publishing long strings to MQTT… and here the problem starts, as I’m total noob here. I have broker configured and working properly, but this is copy/paste configuration required for some other integrations.
So here is what I have so far:
Automation to calll ChatGPT whenever media_album_name for selected medai player changes:
- id: 'update_media_info_2'
alias: Update Media Info 2
initial_state: true
variables:
player: >-
{% set result=states('input_select.media_players') %}
{{ result }}
artist: >-
{% set string=states('input_select.media_players') %}
{% set result=state_attr(string, 'media_artist') %}
{{ result }}
album: >-
{% set result=state_attr(string, 'media_album_name') %}
{{ result }}
output: >-
{% set string=string.split('.') %}
{% set result="input_text." + string[1] + "_media_info" %}
{{ result }}
- platform: state
entity_id:
- media_player.audiocast_dlna
- media_player.denon_heos_s750h
- media_player.marantz_sacd30n
- media_player.volumio_2
attribute: media_album_name
condition: []
- service: chatgpt.chat
- role: user
content: >-
Tell me about {{ artist }}'s album {{ album }} in less than 250 characters
callback_event: >-
{{ player }}_response
Another automation triggered by ChatGPT response and publishing response to MQTT topic:
- id: 'volumio_response'
alias: Volumio Response
- platform: event
event_type: media_player.volumio_2_response
- service: mqtt.publish
topic: "txt/volumio_album"
retain: true
payload: "{{trigger.event.data.content | trim | replace('\"','')}}"
Finally MQTT sensor, that provides this reponse back, so it can easily be used.
mqtt:
- name: "volumio_album"
state_topic: "txt/volumio_album"
Above at least prooves that logic is OK, as it works as expected.
Now the problem is that with this sensor also response is limited to 255 characters… So I’d like to publish/read the response from ChatGPT to sensor attribute… and here I’m lost, whatever I tried it fails woth some errors and sensor is not created/updated. Any advise how to make it? Is it something to be changed on publishing side or sensor or (probavly) both?
