Hi I’m still new to HA and, despite reading a lot of posts and examples (and a bit about jinja2), am unclear on the syntax neccessary for passing variables between components. It seems there are a number of different ways of nesting things and I’m not sure which to use in which situation.
For example it took me a while to figure out that to pass a variable in from an API call, you need need to use the last option for your JSON:
{"data": {"variables": {"minutes": "5"}}}
{"data": {"minutes": "5"} }
{"minutes": "5"} <--- this works
I have an automation, which (surprisingly) works even though it’s using data:
for the first service instead of data_template:
. It’s also using a mix of data: -> variables: -> varname/value
and data_template: -> varname/value
which I’m also surprised works:
- id: start_pump_when_motion
alias: Start the pump when motion detected
- platform: state
entity_id: sensor.vision_zp3111_multisensor_4in1_burglar
to: '8'
- service: script.turn_on
data: # <-- Why does this work without it being "data_template:"?
entity_id: script.notify_slack_pushbullet
variables: # <-- Why does this need to exist?
message: "Motion. Pump started for {{ states.input_number.pump_run_minutes.state | int }} minutes"
- service: shell_command.pump_start_variable_time
data_template: # Maybe this should be "data:"?
seconds: '{{ states.input_number.pump_run_minutes_guest.state | int * 60 }}'
This calls a script which uses a variables:
subsection (as well as data_template
instead of data
, since it’s rendering an incoming variable):
notify_slack_pushbullet:
alias: Notify Slack and PushBullet
sequence:
- service: notify.slack
data_template:
message: "{{ message }}"
- service: notify.pushbullet
title: ''
data_template:
Is there some documentation showing when it’s appropriate to using data:
, variables:
, or both?
Also, why does my action that turns on script.notify_slack_pushbullet
correctly resolve the state.input_number
variable even though it’s not using a data_template
section?
Any enlightenment would be much appreciated.
