I am successfully running nginx at ha.mydomain.net:
domain: ha.mydomain.net
hsts: max-age=31536000; includeSubDomains
certfile: fullchain.pem
keyfile: privkey.pem
cloudflare: false
customize:
active: true
default: nginx_proxy_default*.conf
servers: nginx_proxy/*.conf
But I also want it to respond to tesla.mydomain.net. Hence I need a virtual host. I set customize.active=true and created /share/nginx_proxy/tesla_proxy.conf with following content:
server {
#ssl on;
#ssl_certificate /ssl/fullchain.pem;
#ssl_certificate_key /ssl/privkey.pem;
listen 443 ssl;
server_name tesla.mydomain.net;
location / {
proxy_pass http://127.0.0.1:7277;
However, nginx failed to start then and I had to use my emergency ssh login to even get back access to HA.
Why does this fail?
Could anyone share an example file how to add a virtual host to nginx add-on successfully?
