Hia ll,
I built a ESP8266 board that will monitor and open/close my garage door. it spits out the following per report cycle (set right now to 120 seconds) via MQTT:
- temperature (77F)
- humidity (454)
- heatindex (76F)
- movement (5)
- occupied (yes)
It also accepts a command also via MQTT (command/garage/door: open/close).
I want to set up automation:
If the door is OPEN
AND motion has been 0 for 15 minutes or more
send command/garage/door = close
Is there a way to accumulate motion for the last 15 minutes? At this point I don’t think so unless I resort to the new Python APPDaemon (I think it’s called that…).
IF there isn’t, I might need to change the monitor to report the motion like Unix reports system load: 1min/5min/15min, then parse out the number I want to check. OR report Motion_1m, Motion_5, Motion_15.
It kind of violates my rule of dumb sensors…
So, what do you all think?
Rene’
