@rcruikshank Does your motion sensor send both on and off states? if so, you could do this, I believe it will work as you want.
[{"id":"bc2a0ed5.f96d","type":"server-state-changed","z":"937ef78.ec6b408","name":"Upstairs barthroom Motion off for X minutes?","server":"9405c3fe.d0a6c","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"off","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"2","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":210,"y":240,"wires":[["8782e443.223f18"],["d0d53d9b.15d17"]]},{"id":"8782e443.223f18","type":"api-call-service","z":"937ef78.ec6b408","name":"Light switch OFF","server":"9405c3fe.d0a6c","version":3,"debugenabled":false,"service_domain":"","service":"","entityId":"","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":550,"y":200,"wires":[[]]},{"id":"d0d53d9b.15d17","type":"api-current-state","z":"937ef78.ec6b408","name":"Lux <= 25?","server":"9405c3fe.d0a6c","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"","state_type":"str","blockInputOverrides":false,"outputProperties":[],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":530,"y":260,"wires":[["a47c7db8.62d72"]]},{"id":"a47c7db8.62d72","type":"api-call-service","z":"937ef78.ec6b408","name":"Light switch ON","server":"9405c3fe.d0a6c","version":3,"debugenabled":false,"service_domain":"","service":"","entityId":"","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":700,"y":260,"wires":[[]]},{"id":"9405c3fe.d0a6c","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
More compact
