Hi, I have an ESP8266 that mimic a real candle flame via an LED. It is working fine as it is but currently I am relying on home assistant to turn it on and off.
I would like it to turn on/off automatically without wifi presence and as a standalone device without needing home assistant to be always connected.
I have tried to modify the code but i am stuck and do not know how to continue.
I would like the ESP8266 to always turn on the candle at 5pm each day and then turn off at 8am the next day.
I am not sure how to call the ESP8266 to automatically turn on the GPIO via ESPHOME itself.
Also, will the ESP8266 remember what time it is without wifi? I am not sure about the use of the SNTP platform too.
Could someone please steer me in the right direction?
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: "MyWifi"
password: "Redacted"
manual_ip:
static_ip: 192.168.1.151
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "Candle on timer"
password: "ippMYcFYdccn"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
safe_mode: True
password: "mypassword"
web_server:
port: 80
light:
- platform: monochromatic
output: candle_pwm
default_transition_length: 0s
effects:
- flicker:
alpha: 90%
intensity: 5%
output:
- platform: esp8266_pwm
pin: GPIO2
frequency: 1000 Hz
time:
- platform: sntp
on_time:
# Every evening everyday
- seconds: 0
minutes: 0
hours: 17
days_of_week: MON-SUN
then:
- light.turn_on: my_light
# Every morning everyday
- seconds: 0
minutes: 0
hours: 8
then:
- light.turn_off: my_light
Hellis81
(Hellis81)
January 18, 2022, 10:21am
2
Where is my_light defined?
Isnβt that supposed to be candle
ahh yes it is candle. I mistype there.
When i flash the code to the ESP8266, the code does not seem to run and the candle does not get turn on.
Is there any other error on my code per se? I wonder if the SNTP code is correct to be used this way?
Is it because you have a manual IP address and need to specifiy DNS ?
Also you might need reboot_timeout: 0s
if you plan on using it without WIFI as it will reboot every 10 minutes without WIFI connection. Not sure time will work without WIFI though
lordzid
(Lordzid)
January 18, 2022, 11:23am
5
I would add time check and time conditions. otherwise, if you turn off the electricity after executing your code, the light will not turn on
on_time:
- seconds: /5
lordzid
(Lordzid)
January 18, 2022, 11:25am
6
I can give an example of how I redid sonoff B1 bulb to turn on and off the outdoor lighting in the house according to the height of the sun
lordzid
(Lordzid)
January 18, 2022, 11:27am
7
esphome:
platform: ESP8266
board: esp01_1m
esp8266_restore_from_flash: true
on_boot:
priority: -10
then:
- if:
condition:
- switch.is_on: onboot_sonoffb1
- switch.is_on: stateonboot_sonoffb1
then:
- light.turn_on: blight
- if:
condition:
- switch.is_off: onboot_sonoffb1
then:
- light.turn_off: blight
wifi:
ssid: "SId"
password: "PaSSs"
use_address: 192.168.0.153
fast_connect: true
manual_ip:
static_ip: 192.168.0.153
gateway: 192.168.0.1
dns1: 192.168.0.1
dns2: 8.8.4.4
api:
web_server:
port: 80
logger:
ota:
my9231:
data_pin: GPIO12
clock_pin: GPIO14
num_channels: 6
num_chips: 2
bit_depth: 8
output:
- platform: my9231
channel: 0
- platform: my9231
channel: 1
- platform: my9231
channel: 2
- platform: my9231
channel: 4
- platform: my9231
channel: 5
light:
- platform: rgbww
#restore_mode: ALWAYS_OFF
color_interlock: true
red: output_red
green: output_green
blue: output_blue
cold_white: output_cold_white
warm_white: output_warm_white
cold_white_color_temperature: 6500 K
warm_white_color_temperature: 2800 K
on_turn_on:
switch.template.publish:
state: ON
on_turn_off:
state: OFF
effects:
- random:
name: Random Effect With Custom Values
transition_length: 5s
update_interval: 7s
- flicker:
name: Flicker Effect With Custom Values
alpha: 95%
intensity: 1.5%
- strobe:
name: Strobe Effect With Custom Values
colors:
- state: true
brightness: 100%
red: 100%
green: 90%
blue: 0%
duration: 500ms
- state: false
duration: 250ms
- state: true
brightness: 100%
red: 0%
green: 100%
blue: 0%
duration: 500ms
- pulse:
transition_length: 0.5s
update_interval: 0.5s
- pulse:
# transition_length: 1s # defaults to 1s
update_interval: 2s
- platform: sun
name: "sonoffb1 elevation"
type: elevation
- platform: sun
type: azimuth
binary_sensor:
- platform: status
name: "Sonoff B1 Status"
time:
- platform: sntp
servers:
- 0.ua.pool.ntp.org
- 1.ua.pool.ntp.org
- 2.ua.pool.ntp.org
on_time_sync:
then:
- logger.log: "ΠΡΠ΅ΠΌΡ ΡΠΈΠ½Ρ
ΡΠΎΠ½ΠΈΠ·ΠΈΡΠΎΠ²Π°Π½Π½ΠΎ"
on_time:
- seconds: /5
then:
- if:
condition:
- sensor.in_range:
below: '-0.0'
- switch.is_on: deynight_sonoffb1
- light.is_off: blight
then:
- light.turn_on:
brightness: 100%
cold_white: 100%
color_temperature: 154 mireds
#color_mode: WHITE
- if:
condition:
- sensor.in_range:
above: '-0.0'
- light.is_on: blight
then:
- light.turn_off:
sun:
latitude: 46.2931Β°
longitude: 30.3438Β°
switch:
- platform: restart # ΠΠ½ΠΎΠΏΠΊΠ° ΠΏΠ΅ΡΠ΅Π·Π°Π³ΡΡΠ·ΠΊΠΈ
- platform: template # ΠΊΠ½ΠΎΠΏΠΊΠ° Π΄Π΅Π½Ρ Π½ΠΎΡΡ
name: "Day/Night sonoff-b1 "
icon: 'mdi:theme-light-dark'
optimistic: true
- platform: template # ΠΊΠ½ΠΎΠΏΠΊΠ° ΠΊΠ½ΠΎΠΏΠΊΠ° ΡΠΎΡΡΠΎΡΠ½ΠΈΡ ΠΏΡΠΈ Π·Π°Π³ΡΡΠ·ΠΊΠ΅
#name: "On boot sonoff-b1 "
#icon: 'mdi:theme-light-dark'
optimistic: true
restore_state: true
name: "State on boot sonoff-b1 "
optimistic: true
restore_state: true
icon: 'mdi:lightbulb-group-outline'
optimistic: true
turn_on_action:
then:
- light.turn_on:
brightness: 100%
red: 0
green: 100%
blue: 0
- delay: 1s
- switch.template.publish:
state: Off
optimistic: true
turn_on_action:
then:
- light.turn_on:
brightness: 100%
red: 0
green: 0
blue: 100%
- delay: 1s
state: Off
optimistic: true
turn_on_action:
then:
- light.turn_on:
brightness: 100%
red: 100%
green: 0
blue: 0
- delay: 1s
state: Off
optimistic: true
turn_on_action:
then:
- light.turn_on:
brightness: 100%
red: 50%
green: 0
blue: 50%
- delay: 1s
state: Off
optimistic: true
turn_on_action:
then:
- light.turn_on:
brightness: 100%
red: 9%
green: 86.7%
blue: 92.2%
- delay: 1s
state: Off
optimistic: true
turn_on_action:
then:
- light.turn_on:
brightness: 100%
red: 90.6%
green: 100%
blue: 0.4%
- delay: 1s
state: Off
text_sensor:
- platform: wifi_info
ssid:
ip_address:
name: "Sonoff-b1 IP Address"
- platform: sun
type: sunrise
- platform: sun
type: sunset
switch id: daynight_sonoffb1 doors the ability to enable and disable automation.
Thanks for that reboot_timeout. That might have been the issue why it wasnt working in my case but I am not entirely sure. I have now put in that line.
Thanks lordzid.
Am I understanding correctly that is running the script every 5 seconds? If so, I donβt quite understand why?
Thanks mate. If I am going to run without wifi, will the SNTP part still work?
lordzid
(Lordzid)
January 18, 2022, 11:47am
11
I will give an example: the sunset has come. the light should turn on. power outage for some reason and then appeared. your condition will not be met.
lordzid
(Lordzid)
January 18, 2022, 11:48am
12
Sntp will work until the power is turned off. after turning on, you need to synchronize the clock. There are separate modules for this.
Do you mean that the 5seconds time delay will happen everytime before the switching on of the GPIO?
so in my case if i wanted to switch on the GPIO at 5pm everyday, then this is telling the ESP8266 to wait 5 seconds first before switching on?
so what happens if my ESP8266 has a power failure, it wonβt continue to boot because it is trying to connect to internet to synchronize the clock?
lordzid
(Lordzid)
January 18, 2022, 12:09pm
15
no, the device will turn on and everything will work, but no time-related automations will be performed
sorry not sure what you are referring toβ¦are u referring to nothing will work because it cannot connect to the internet to synchronize the clock or are you referring to the 5 seconds delay?
Getting more confused.
lordzid
(Lordzid)
January 18, 2022, 12:31pm
17
I mean: if the Internet is disconnected, there will be no time synchronization and the conditions will not be met. when there is synchronization, every 5 seconds a check for conditions is performed and everything will work
I see! I understand now.
in my case i wanted the esp8266 to switch on automatically at 5pm and off at 8am even when there is no internet and no wifi. What should i do?
lordzid
(Lordzid)
January 18, 2022, 12:42pm
19
you will need This is a module And customize it. and make code.
Thanks. I will check out the GPS module - although I am not sure if my ESP8266 supports GPS.
