I’m using a button to open and close my garage door from HA mobile.
But my wife is also using the physical button (remote control) of the garage door.
Consequence : The button does not sync with the current state of the door :
For instance :
Opening with HA : OK
Then my wife use its remote control to close the door.
This is what I get then :
state closed but button still “on”
PS: i’m also dealing with the fact that if I want to stop the garage door during the closing, I can do it but need to pulse twice to close definitely the door due to this problem…
How is the boolean connected to the function of the door? An Automation? We’ll need the details to help you figure out a better approach, if there is one.
Sorry but I don’t following you. I have a zigbee garage door opener which give me 2 entities : sensor + switch. I just add the 2 of them in the card, that’s it
well probleme solved with automations, maybe not the quickest but works !
1 automation to control if the sensor state is open “on” then => call service / trigger ON the device
1 automation to control if the sensor state is open “off” then => call service / trigger OFF the device
