How to sync different entities
I have 2 different devices (integrations) for my climate unit. One is via IR (via Tasmota) and another via local LAN. Is there a way to sync data between them- if I adjust e.g. temp in one of my device settings - can it be reflected in another one?
If it is possible at all I am willing share further details :slight_smile:
TIA, Reps
It could be done with two automations. This will require the use of templates.
Automation 1:
triggers:
on change of state of climate 1 setpoint, fan, etc…
actions:
disable automation 2 (to prevent looping)
set climate 2 setpoint, fan, etc to climate 1 values.
enable automation 2
Automation 2:
triggers:
on change of state of climate 2 setpoint, fan, etc…
actions:
disable automation 1 (to prevent looping)
set climate 1 setpoint, fan, etc to climate 2 values.
enable automation 1
You might also be able to combine them both with a template climate controller, but I don’t know enough about it to say for sure.
Thanks, something about I was working on and concerned about looping etc. My humble hope was something simpler and direct :frowning: Will investgate further :slight_smile:
TIA, Reps
Now you have the solution to that.
Yeah that’s why I mentioned:
Hopefully someone else may have an idea how this can be done.
