How to Sync your old IR Stereo with the Chromecast's Volume
Lately, I’ve been fascinated with idea of derivative helpers within Home Assistant. I thought this was a neat example case: My TV inputs the sound into the stereo amplifier via an optical audio cable which does not relay volume changes. Before, I had to manually control the stereo with a IR remote or IR blaster. Now, I have my IR blaster (Broadlink) controlled stereo synchronized with the Chromecast volume controls! Here’s how you can too:
  1. Create a yaml template sensor with the state_attr() of the chromecast’s volume multiplied by 100 (%).
  2. Create a derivative helper imputing this sensor’s volume.
  • Thus a derivative >0 indicates a desire to increase the volume
  • And a derivative <0 indicates a desire to decrease the volume.
  1. Set up automations that trigger when the derivative reaches certain thresholds (example below). The action should increase or decrease the stereo’s volume via IR command in proportion to the derivative.
  • 3-6 = volume +++
  • 1-3 = volume ++
  • 0.01-1 = volume +
  • (-1)-(-0.01) = volume -
  • (-3)-(-1) = volume –
  • (-6)-(-3) = volume —
  1. Create a separate automation that examines the sensor’s volume such that when it is 0% the stereo is muted and when it is 100% the stereo is un-muted.
The end result is your non-smart stereo can be controlled by your phone/PC within the casted player!
