I have inovelli dimmer switches. I downloaded a palette which is supposed to let me automatically change the LED color, strip effect, etc. It doesnt work.
BUT…
the value it spits out is correct. And if I send this value to the switch in a call service node, the switch responds accordingly.
So what I want to do is take the value that the zwave node spits out, currently it will spit out 35523243 and I want to import that into my Set LED node data field, which is currently a 1. Is this possible?
Picture below and flow attached if anyone can modify for me.
[{"id":"c7a24234.cfeb1","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"b8d7007c.5d74","type":"inovelli-status-manager","z":"c7a24234.cfeb1","name":"zwave","nodeid":"14","color":"181","level":10,"duration":30,"display":"2","switchtype":"16","x":300,"y":120,"wires":[["7de49816.5758e8"]]},{"id":"cfd93d1b.f2771","type":"inject","z":"c7a24234.cfeb1","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":110,"y":120,"wires":[["b8d7007c.5d74"]]},{"id":"7de49816.5758e8","type":"api-call-service","z":"c7a24234.cfeb1","name":"","server":"456659de.370498","version":1,"debugenabled":false,"service_domain":"zwave","service":"set_config_parameter","entityId":"","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":570,"y":120,"wires":[[]]},{"id":"b21e9a00.94ad78","type":"api-call-service","z":"c7a24234.cfeb1","name":"Set LED","server":"456659de.370498","version":1,"debugenabled":false,"service_domain":"zwave","service":"set_config_parameter","entityId":"","data":"{\"node_id\":14,\"parameter\":16,\"size\":4,\"value\":1}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":480,"y":280,"wires":[[]]},{"id":"6daabf45.340a4","type":"inovelli-status-manager","z":"c7a24234.cfeb1","name":"zwave","nodeid":"14","color":"181","level":10,"duration":30,"display":"2","switchtype":"16","x":300,"y":280,"wires":[["b21e9a00.94ad78"]]},{"id":"9b904088.ac83d","type":"inject","z":"c7a24234.cfeb1","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":110,"y":280,"wires":[["6daabf45.340a4"]]},{"id":"a34a2850.6d1708","type":"comment","z":"c7a24234.cfeb1","name":"This does not work, although it should","info":"","x":180,"y":80,"wires":[]},{"id":"2a2ff22.94cfc0e","type":"comment","z":"c7a24234.cfeb1","name":"How do I automatically insert the \"value\" of zwave node, currently 35523243 into the Set LED call service node value which is currently 1","info":"","x":530,"y":240,"wires":[]},{"id":"456659de.370498","type":"server","z":"","name":"Home Assistant","addon":true}]
