How to tell why my ceiling fans are turning off
Every day at 1:01 or 1:02 AM, my garage ceiling fans shut off. They are controlled with a GE Enbrighten zwave switch. I cannot find any automation that would be turning them off. How do I tell what is causing them to turn off?
Did you ever find the problem? I am having the same thing happpening, with the Embrighten zwave fan controller. It gets worse when I try to go to the 2024.6.1 core update. It turns on, but then shuts off within a minute.
Turn on debug logging in zwavejs, then look at the log file to see if an application command is being sent. If it is then something in HA is turning it off.
The only thing I see is the owner turns it on. Later, the supervisor turns it off. Happens in core 2024-6.x. Does not happen in core 2024-5.5.
June 8, 2024
Turned off triggered by service Fan: Turn off
8:00:42 PM - 34 seconds ago - Supervisor
Turned on triggered by service Fan: Turn on
8:00:01 PM - 1 minute ago - Owner
7:57:42 PM - 4 minutes ago - Supervisor
Turned on triggered by service Home Assistant Core Integration: Generic turn on
7:57:32 PM - 4 minutes ago - Owner
I figured it out. Alexa had a ‘hunch’ that it was left on. So that’s fun
