How to template MQTT sensor JSON as entity + attributes
Hello guys,
I know that there are many topics on templating subjects and believe me I went through a lot of them!
I have in my configuration.yaml an MQTT sensor:
mqtt:
# TXsoil sensors
    - name: "sms_txsoil1"
      state_topic: "sms_wf1_out_tx-o-txsoil1"
      value_template: '{{ value_json.Humidity }}'
      unit_of_measurement: '%'
The string sent by this sensor is:
{"B":94,"W":1,"Humidity":8,"Date":20220909,"Time":1900,"Name":TXsoil1,"Device":TXsoil,"H":"CE6408"}%
My goal would be to extract “Humidity” as entity and the rest of the values as attributes of this entity.
At the moment the only thing that I got with the code in the configuration.yaml is:
"unkwnown"
Since I was not even able to extract one value from the json string I stop there start searching for solutions and as I said couldn’t find anythng meaningful.
Can anybody help?
thanks
Luca
Luca,
No answer for you but offering moral support as I am stumped with a similar query and result.
Dan
Thanks Dan! waiting for somebody more proficient!
Just as a check, an MQTT topic is usually of the form xxx/yyy/zzz. It doesn’t have to be, but just wanted to double-check first to make sure that your topic was not the issue.
Is this definitely what is posted on the MQTT topic, and you haven’t made any mistakes? Because the % at the end of this string of text, makes this invalid JSON which Home Assistant won’t be able to parse.
So in addition to what @mobile.andrew.jones is saying, I noticed you had some invalid json inside the object that will cause errors.
Specifically
Those 2 fields, the results are unquoted strings which is not valid. That means value_json will not work for you.
You’ll have to use regex
      value_template: >
        {{ value | regex_findall('"Humidity":([0-9.]+),')[0] }}
EDIT: Also you have odd quoting that you have to overcome, so you’ll have to use multiline notation.
feedbacks clear… this is exactly the content of the message that I receive from the MQTT sensor. From my understanding there is a “%” simbol that is not in line with the JSON format as well as the unquoted strings. Thanks for your feedbacks, I’ll come back when I will have the JSON formt corrected.
folks,
I got the MQTT payload corrected with all quotes (thanks Petro!)
{"B":92,"W":1,"Humidity":7,"Date":20220915,"Time":2023,"Name":"TXsoil1","Device":"TXsoil","H":"CE6407"}
And now the command below actually extracts the desired value (7) :
mqtt:
# TXsoil sensors
Now I am back to my original questions: how to extract from the MQTT payload “Humidity” as entity and the rest of the values as attributes of this entity.
thanks
mqtt:
# TXsoil sensors
      json_attributes_template: "{{ value_json | tojson }}"
Reference: JSON attributes template configuration
This should identical. I.e. if it can be converted from json into value_json, then it’s already a json string, so there’s no reason to double convert
      json_attributes_template: "{{ value }}"
Interestingly, the example in the documentation uses to_json even when the sample payload contains an obvious JSON dictionary. Its use in this situation seems redundant to me as well but I deferred to the example.
huh, odd. :man_shrugging:
ok, made it work:
mqtt:
# TXsoil sensors
      json_attributes_topic: "sms_wf1_out_tx-o-txsoil1"
      json_attributes_template: '{{ value_json | tojson }}'
actually suggestion from 123 was correct but you have to add this line:
Final result in the States tab is:
So exactly what I was looking for.
Thanks to all and hope this topic will be useful
Observations originally reported in this post cannot be duplicated so I have collapsed it (content retained for the curious).
Original post
Actually, you should not have to include json_attributes_topic. Or at least you did not have to include it in the past. If it was left out, the sensor would simply default to using the state_topic as the source for attributes.
However, its new behavior differs from the past and may due to a bug. Here’s what I mean:
I can confirm your observation that when the MQTT Sensor is first created, if you leave out json_attributes_topic it fails to create attributes from the payload received via the state_topic. Afterwards, if you add json_attributes_topic it will then create attributes.
With json_attributes_topic
However, I then removed json_attributes_topic (reloaded ‘Manually created MQTT entities’, as always, to load the new configuration) and the sensor continued to create attributes and report their correct values.
Without json_attributes_topic
Attributes are still created and updated with the new published values.
Just to confirm I wasn’t imagining things, I restarted Home Assistant, published a new payload and the sensor reported attributes … all without a json_attributes_topic. That’s the correct behavior it always had … until now when it fails to do this when the sensor is initially created.
I repeated the test to confirm my observations.
  1. I removed the MQTT Sensor’s configuration, reloaded, and it disappeared from the system.
  2. I added the MQTT Sensor’s configuration (without json_attributes_topic), reloaded, and it appeared (with no value or attributes).
  3. I published a payload and the sensor reported a value but no attributes.
  4. I added json_attributes_topic to the sensor’s configuration and reloaded.
  5. I published a new payload and the sensor reported a value and attributes.
  6. I removed json_attributes_topic from the sensor’s configuration and reloaded.
  7. I published a new payload and the sensor reported a value and attributes (i.e. without having a json_attributes_topic).
This new behavior suggests it’s a bug that occurs exclusively when the MQTT Sensor is initially created.
NOTE
The test was performed using 2022.8.7.
EDIT
Fixed typos.
Original post
If you have a moment to spare, see if you can duplicate my results.
  • Confirm your existing sensor is currently reporting attribute values.
  • Remove the following line and then reload ‘Manually created MQTT entities’
  • Publish a new payload to sms_wf1_out_tx-o-txsoil1.
  • Confirm the sensor continues to report attribute values.
Let me know your results. If they are identical to mine, I will report this as a bug in the GitHub Core repository. In addition, let me know which version of Home Assistant you are using.
UPDATE
Well, oddly enough, I can no longer replicate my own results. :thinking: :man_shrugging: :man_facepalming:
I’ll have to chalk it up to a mistake in my testing procedure (where exactly, I don’t know) because I can no longer get it to work without including json_attributes_topic. Very strange because I swear it used to work without it in previous versions. Oh well.
very strange…
I have been trying for hours without success to somehow integrate a json including attributes as a sensor, but so far without any success. I have tried all the different configurations that I found here in the forum, but it still doesn’t work. I can retrieve the json as text, but not as individual values.
The json looks something like this:
{"depot":1,
"isin":"US12345667890","name":"Bullshit","preis":105.9247,"min":0,"max":0,"delta":+5.32,"stueck":160}
My current mqtt configuration:
  - name: "Aktien JSON"
    state_topic: "aktien/json"
    value_template: "{{ value_json.preis }}"
    json_attributes_topic: "aktien/json"
Does anyone have any ideas or tips?
It was a stupid mistake - a + plus inside a number field. It’s running now correctly :slight_smile:
Old post I know but…
Data is (from acpi)
    "type": "Battery",
    "id": "0",
    "state": "Charging",
    "charge_percent": "98",
    "until_charged": "00:08:02"
sensor definition
  - name: "pve_battery"
    state_topic: "pve/acpi/data"
    value_template: "{{ value_json[0].charge_percent }}"  # Using charge_percent as the state
    json_attributes_topic: "pve/acpi/data"
    json_attributes_template: '{{ value_json[0] | tojson }}'    # attributes:
Output -
It will not process the key:value pair of state:value
Any solutions?
map the values to different attributes.
