Hmm, I know about editable install (run from checkout instead of installing to default location, if I recall it just links) as the problem abstract is not to have an editable version of code (I don’t mind remote changes, pull, reinstall) but the fact that:
without restart, just reloaded integration from GUI, the changes aren’t picked up
restarting ha, after restart, pip freeze version resets back to 3.2.1 (nonlocal install)
I don’t think that will help, will give it a try though!
homeassistant:/home/dev/solax# pip install -e .
Looking in indexes: https://pypi.org/simple, https://wheels.home-assistant.io/musllinux-index/
Obtaining file:///home/dev/solax
Preparing metadata (setup.py) ... done
Requirement already satisfied: aiohttp<4,>=3.5.4 in /usr/local/lib/python3.13/site-packages (from solax==3.1.2.dev9+g2cccfca) (3.11.9)
Requirement already satisfied: voluptuous>=0.11.5 in /usr/local/lib/python3.13/site-packages (from solax==3.1.2.dev9+g2cccfca) (0.15.2)
Requirement already satisfied: aiohappyeyeballs>=2.3.0 in /usr/local/lib/python3.13/site-packages (from aiohttp<4,>=3.5.4->solax==3.1.2.dev9+g2cccfca) (2.4.4)
Requirement already satisfied: aiosignal>=1.1.2 in /usr/local/lib/python3.13/site-packages (from aiohttp<4,>=3.5.4->solax==3.1.2.dev9+g2cccfca) (1.3.1)
Requirement already satisfied: attrs>=17.3.0 in /usr/local/lib/python3.13/site-packages (from aiohttp<4,>=3.5.4->solax==3.1.2.dev9+g2cccfca) (24.2.0)
Requirement already satisfied: frozenlist>=1.1.1 in /usr/local/lib/python3.13/site-packages (from aiohttp<4,>=3.5.4->solax==3.1.2.dev9+g2cccfca) (1.5.0)
Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.13/site-packages (from aiohttp<4,>=3.5.4->solax==3.1.2.dev9+g2cccfca) (6.1.0)
Requirement already satisfied: propcache>=0.2.0 in /usr/local/lib/python3.13/site-packages (from aiohttp<4,>=3.5.4->solax==3.1.2.dev9+g2cccfca) (0.2.1)
Requirement already satisfied: yarl<2.0,>=1.17.0 in /usr/local/lib/python3.13/site-packages (from aiohttp<4,>=3.5.4->solax==3.1.2.dev9+g2cccfca) (1.18.3)
Requirement already satisfied: idna>=2.0 in /usr/local/lib/python3.13/site-packages (from yarl<2.0,>=1.17.0->aiohttp<4,>=3.5.4->solax==3.1.2.dev9+g2cccfca) (3.10)
Installing collected packages: solax
Attempting uninstall: solax
Found existing installation: solax 3.2.1
Uninstalling solax-3.2.1:
Successfully uninstalled solax-3.2.1
DEPRECATION: Legacy editable install of solax==3.1.2.dev9+g2cccfca from file:///home/dev/solax (setup.py develop) is deprecated. pip 25.0 will enforce this behaviour change. A possible replacement is to add a pyproject.toml or enable --use-pep517, and use setuptools >= 64. If the resulting installation is not behaving as expected, try using --config-settings editable_mode=compat. Please consult the setuptools documentation for more information. Discussion can be found at https://github.com/pypa/pip/issues/11457
Running setup.py develop for solax
Successfully installed solax-3.1.2.dev9+g2cccfca
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager, possibly rendering your system unusable.It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv. Use the --root-user-action option if you know what you are doing and want to suppress this warning.
Yep, after reload - no change in the sensor I checked, after the restart of homeassistant:
An editable install, yes, will link it such that when you amend the code, you do not have to install it again, but yes, you always have to reatart HA to pick up modified code.
I presume you are not changing the required version in requirements_all.txt to reflect the version of your modified library, which is why it is installing the one specified in the requirements file on every restart.
