There are a couple ways to add voice intents for Alexa. If you want something that succinct, I think you are limited to using a Routine in the Alexa app. If there is only one “lamp” you can handle that directly in the routine, otherwise you will need to point the routine at a script that can handle the necessary logic to match the active room with the lamp.
