I have about 70 entities dynamically created by a monitoring system (and their state updated periodically). They are not configured in Home Assistant configuration files.
Most of the states are ok
(hopefully all of them), but when a state is ko
I would like an icon for that state to appear (and disappear when the state is back to ko
I am completely open to the way it is done (I would like to just avoid badges at the top of a tab, as I use that area to display statuses such as temperatures). I use both
- an external program to monitor the availability of my home devices and Home Assistant as the state manager (the program does a
POST
to the API) - and Appdaemon to manage automations
so if there is a need to send something somewhere I am all for it. I just do not know how to approach the problem.
I saw that there was the possibility to set the visibility of whole groups (https://www.home-assistant.io/docs/configuration/group_visibility/) but I need to work on the level of an entity.
