I have moved and now have oil heating in the house. Since I have already integrated everything possible in Home Assistant, it is now obvious to also track the oil consumption and thus get an overview of the total energy costs.
I calculate the oil consumption with the help of a Shelly (querying the time over a certain oil consumption) and the oil throughput per hour. This all works well so far. The conversion to kWh should also be reasonably accurate thanks to the information about my burner.
Unfortunately, I can’t get the consumption correctly into my energy dashboard now, as the built entity resets to 0 every day at 00:00. So I have then no reasonable tracking in the energy dashboard.
I also tried to save the values using a helper consumption counter, but since the input value resets to 0 at night, I don’t get any usable values here.
Do you have any idea how I can work around this?
I have attached an example image of my daily consumption counter.
I am trying to do the same , to find my burner consumption and quantity of oil burned or left in the tank . I have the entity that count how many time and how long the burner has run but cannot figure out a way to get an helper to compute the result. I know the pgh consumption of my burner.
