How to transfer a bluetooth headset microphone from Debian 11 to Home Assistant Rhasspy Assistant?
How to transfer a bluetooth headset microphone from Debian 11 to Home Assistant, in the Rhasspy Assistant addon. There is a bluetooth headset with a microphone. Home Assistant is installed on Debian 11, on a Beelink U59 Pro mini PC, which has built-in bluetooth. In Debian 11, the bluetooth headset works properly, plays sound and records from the microphone, but in the Home Assistant, the microphone does not work, only the sound works. I need a microphone for Rhasspy Assistant so that I can connect a bluetooth speaker with a microphone and control the smart home by voice, but unfortunately the microphone does not want to work in Rhasspy Assistant.
What have I done?
Brought out the available sound cards with the command
pacmd list-cards
Displayed the available active profiles with the command
pacmd list-cards | grep 'active profile'
Further, knowing the bluetooth headset profile, I assigned an active profile for the bluetooth headset, after checking with the command
pacmd set-card-profile bluez_card.54_42_49_A5_56_AB headset_head_unit
After it worked, I added the code to `/etc/pulse/default.pa’. I found the answer here
.ifexists bluez_card.54_42_49_A5_56_AB
pactl set-card-profile bluez_card.54_42_49_A5_56_AB headset_head_unit
.endif
I tried to assign an input for the microphone in order to transfer it to the Home Assistant, but it didn’t work out for me
pactl set-sink-port bluez_sink.54_42_49_A5_56_AB.headset_head_unit handsfree-input
Microphone recording works in Debian 11. Checking the recording from the microphone. The command to record from the microphone.
arecord -d 5 test_record.wav
5 - recording time in seconds, you can specify any number of seconds
test_record - file name
Run the recorded file
aplay test_record.wav
Next, open the SSH & Web Terminal in the Home Assistant and enter the command
pacmd list cards, where the available sound cards are displayed and it has a bluetooth headset
Output of sound cards with the command
ha audio info
The bluez_card.54_42_49_A5_56_AB profile cannot be assigned with the command
ha audio profile --card "1" --name "headset_head_unit"
It is not possible to assign a default input
ha audio default input --name 'bluez_card.54_42_49_A5_56_AB headset_head_unit'
I tried to add /etc/pulse/client.conf to the config
default-server = unix:/usr/share/hassio/audio/external/pulse.sock
but in fact, it’s better not to do this, since the sound still works, and the microphone is not transmitted, but we lose the ability to control the device in Debian 11, the Dummy Output device is selected all the time. So I left the default-server as it is. The sound is transmitted to the speaker from both Debian 11 and Home Assistant
default-server =
I tried using docker to assign by default
Viewing audio devices and assigning default devices
Withdraw all cards
docker exec -it hassio_audio pactl list
View the list of available maps
docker exec -it hassio_audio pactl list short sinks
Assign a default map
docker exec -it hassio_audio pactl set-default-sink 1
Did you look at this Select default audio device - #5 by arminJacobson , it look like HA need to assign the default input or it will not work, you probably need to change the profile of the sound device
" How to change the profile of a sound device
Thanks to this page from the Arch wiki, I was able to change the profile using pactl. The syntax is as follows:
pactl set-card-profile <symbolic-name> <profilename>
Thanks for the reply. I note that razer’s built-in sound and usb sound card work fine and transmit sound to the addon Rhasspy Assistant, if you add /etc/pulse/client.conf to the config, but this does not help for a bluetooth headset
I tried what you suggested and unfortunately it didn’t help, swears at input and output
I have tried various options
I tried the option with the choice of index or map
pactl set-card-profile 7 headset_head_unit
pactl set-card-profile 1 headset_head_unit
I looked at the specification of my old Sony DR-BT50 bluetooth headphones here. These headphones support A2DP, AVRCP, HFP, HSP profiles
And here’s what I found. Here write that
My earbuds profiles were A2DP, AVRCP and HFP and no support for HSP. Pulseaudio only supports HSP out-of-the-box. That’s why I couldn’t switch to HSP/HFP. In order to make HSP/HFP work, you have to enable HFP on pulseaudio which needs ofono.
I installed ofono using this instruction and it didn’t help. I note that ofono did not start successfully for me right away, since not everything went smoothly as in the instructions, but after I figured it out, I managed to launch ofono. Here’s how I made ofono run on Debian 11.6
Installing ofono on Debian 11.6
sudo apt update
sudo apt install ofono
sudo usermod -aG bluetooth pulse
Add to default.pa with the nano command /etc/pulse/default.pa
load-module module-bluetooth-discover headset=ofono
Added to ofono.conf with the nano /etc/dbus-1/system.d/ofono.conf command
  <policy user="pulse">
    <allow send_destination="org.ofono"/>
  </policy>
Adding /etc/apt/sources.list to the repositories
nano /etc/apt/sources.list
deb https://ppa.launchpadcontent.net/smoser/ppa/ubuntu focal main
deb-src https://ppa.launchpadcontent.net/smoser/ppa/ubuntu focal main
Launch and press Enter
sudo add-apt-repository ppa:smoser/ppa
Updating repositories
sudo apt update
If, after updating packages with the sudo apt update command , it swears
Repository “Index of /smoser/ppa/ubuntu lunar Release” does not contain a Release file.
Then you need to fix the OS version in the repository, specify focal instead of lunar. For understanding, Debian 11.6 has the name bullseye, and Ubuntu 20.04, which is built on the Debian build, has the name focal and impish. You need to edit all the files in the /etc/apt/sources.list.d folder/
ls /etc/apt/sources.list.d/
It was
Changing lunar to focal in the smoser-ubuntu-ppa-lunar.list file
cd /etc/apt/sources.list.d/
sed -i 's/\lunar\b/focal/g' smoser-ubuntu-ppa-lunar.list
After replacing lunar with focal, it should be like this
Install some pre-requisites:
sudo apt install devscripts build-essential software-properties-common -y
Add the signing key to your system:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys B59D5F1597A504B7E2306DCA0620BBCF03683F77
Create the list file using the deb-src URL by adding the following to /etc/apt/sources.list.d/smoser-ubuntu-bluetooth-focal.list:
nano /etc/apt/sources.list.d/smoser-ubuntu-bluetooth-focal.list
deb-src http://ppa.launchpad.net/smoser/bluetooth/ubuntu focal main
sudo apt update
After updating the packages with the sudo apt update command, it will swear again
Repeat and change lunar to focal in the new smoser-ubuntu-bluetooth-focal.list file
sed -i 's/\lunar\b/focal/g' smoser-ubuntu-bluetooth-focal.list
After that, you can ignore the warnings
NOTE: If you want to try a different Ubuntu release instead of focal make sure you consult the mapping
At this point you should be able to run sudo apt update and not see any errors.
As noted above and in the referenced docs, we need to build a Debian package and can’t use what is in the PPA directly.
I try and stay organized:
mkdir -p ~/ppa/pkg-ofono-phonesim
cd ~/ppa/pkg-ofono-phonesim
apt install qtbase5-dev qtdeclarative5-dev -y
apt source -t focal --build ofono-phonesim
Если все сделано правильно, то будет вот так
At the end we should have the file ofono-phonesim_1.21-16-gadf231a8-0smoser0_amd64.deb
Now you should have a .deb file in the current directory so you can just install it:
sudo dpkg -i ofono-phonesim_1.21-16-gadf231a8-0smoser0_amd64.deb
Create a file called /etc/ofono/phonesim.conf with the following contents:
[phonesim]
Driver=phonesim
Address=127.0.0.1
Port=12345
Then we do as in the instructions, but with some changes
Create systemd Services to Manage ofono and ofono-phonesim
This is where we introduct what I think are a few improvements.
You will want to grab some official scripts from ofono:
sudo git clone git://git.kernel.org/pub/scm/network/ofono/ofono.git /opt/ofono
In addition, grab some scripts I wrote that make this all work better:
git clone https://github.com/davidnewman/control-phonesim.git ~/github.com/davidnewman/control-phonesim
Follow the instructions in the README.md file to set that up.
Create a file called /etc/systemd/system/ofono-phonesim.service with the following contents:
[Unit]
Description=Run ofono-phonesim in the background
Requires=ofono.service
After=ofono.service
[Service]
ExecStart=ofono-phonesim -p 12345 /usr/share/phonesim/default.xml
Type=simple
RemainAfterExit=yes
[Install]
WantedBy=multi-user.target
Create a file called /etc/systemd/system/phonesim-enable-modem.service with the following contents:
[Unit]
Description=Enable and online phonesim modem
Requires=ofono-phonesim.service
[Service]
ExecStart=/opt/ofono/test/enable-modem /phonesim  /opt/ofono/test/enable-modem
ExecStart=/opt/ofono/test/online-modem /phonesim
Type=oneshot
RemainAfterExit=yes
[Install]
After we have added it, we run the commands sequentially
sudo systemctl daemon-reload
sudo systemctl enable ofono-phonesim.service
sudo systemctl enable phonesim-enable-modem.service
sudo service phonesim-enable-modem start
sudo service phonesim-enable-modem status
If everything is done correctly, then when checking the status with the command, we should see that the phone sim-enable-modem service is running
You can also check whether ofono works in this way
Log out of the root account and run
systemctl --user restart pulseaudio
And at the end, we will comment out the repositories /etc/apt/sources.list. we won’t need them anymore
#deb https://ppa.launchpadcontent.net/smoser/ppa/ubuntu focal main
#deb-src https://ppa.launchpadcontent.net/smoser/ppa/ubuntu focal main
and delete the files moser-ubuntu-bluetooth-focal.list and smoser-ubuntu-ppa-lunar.list in /etc/apt/sources.list.d/
rm smoser-ubuntu-bluetooth-focal.list  smoser-ubuntu-ppa-lunar.list
That’s it, now we go into debian 11, the microphone worked and works, the HSP profile is selected.
In the console, enter the command to display a list of sound cards and see that the headset_head_unit profile is activated
pacmd list-cards
Find out active profiles
pacmd list-cards | grep ‘active profile’
Then in /etc/pulse/client.conf I add to default-server =
nano /etc/pulse/client.conf
autospawn = no
I save, log out of root and restart pulseaudio with the command
pulseaudio -k && pulseaudio --start
I go to the Home Assistant in the SSH & Web Terminal and enter
ha audio info
there are no devices
next, I enter the pactl list cards and see my Sony DR-BT50 bluetooth headphones with the A2DP profile activated, and the headset_head_unit profile deactivated
pactl list cards
далее я пытаюсь активировать профиль headset_head_unit командами
I restart ha audio with the command, I see that the A2DP profile is activated
ha audio reload
Текст на русском (Text in Russian)
Спасибо за ответ. Отмечу, что встроенная звуковая и usb звуковая карта razer отлично работают и передают звук в аддон Rhasspy Assistant, если добавить в конфиг /etc/pulse/client.conf, но это не помогает для bluetooth гарнитуры
Попробовал, что вы предложили и к сожалению это не помогло, ругается на ввод и вывод
Я пробовал различные варианты
Попробовал вариант с выбором индекс или карты
Посмотрел спецификацию моих старых bluetooth наушников Sony DR-BT50 здесь. Эти наушники поддерживают профили A2DP, AVRCP, HFP, HSP
И вот что я нашел. Тут пишут, что
Я установил ofono по этой инструкции и это не помогло. Отмечу, что ofono не сразу у меня успешно запустилось, так как не все шло гладко как в инструкции, но разобравшись, у меня получилось запустить ofono. Вот как я сделал, чтобы ofono запустилось на Debian 11.6
Установка ofono на Debian 11.6
sudo apt update
Добавим в default.pa командой nano /etc/pulse/default.pa
Добавил в ofono.conf командой nano /etc/dbus-1/system.d/ofono.conf
  </policy>
Добавляем в репозитории /etc/apt/sources.list
Запускаем и нажимаем Enter
Обновляем репозитории
sudo apt update
Если после обновления пакетов командой sudo apt update будет ругаться
То нужно исправить версию ОС в репозитории, вместо lunar указать focal. Для понимания, Debian 11.6 имеет имя bullseye, а Ubuntu 20.04 которая собрана на сборке Debian имеет имя focal и impish. Нужно отредактировать все файлы в папке /etc/apt/sources.list.d/
Было
Меняем lunar на focal в файле smoser-ubuntu-ppa-lunar.list
После замены lunar на focal должно быть так
sudo apt update
После обновления пакетов командой sudo apt update снова будет ругаться
Повторяем и меняем lunar на focal в новом файле smoser-ubuntu-bluetooth-focal.list
После этого можно игнорировать предупреждения
В конце у нас должен появиться файл ofono-phonesim_1.21-16-gadf231a8-0smoser0_amd64.deb
[phonesim]
Driver=phonesim
Address=127.0.0.1
Port=12345
Дальше делаем как в инструкции но с некоторыми изменениями
[Unit]
After=ofono.service
[Service]
Type=simple
RemainAfterExit=yes
[Install]
[Unit]
[Service]
Type=oneshot
RemainAfterExit=yes
[Install]
После того как добавили запускаем команды последовательно
Если все сделано верно, то при проверки статуса командой мы должны увидеть, что служба phonesim-enable-modem запущена
Можно еще проверить работает ли ofono таким способом
Выходим из учетной записи root и запускаем
И под конец в закомментируем репозитории /etc/apt/sources.list. они нам больше не понадобятся
и удалим файлы moser-ubuntu-bluetooth-focal.list и smoser-ubuntu-ppa-lunar.list в /etc/apt/sources.list.d/
На этом все, теперь заходим в debian 11, микрофон как работал, так и работает, профиль HSP выбран.
В консоле вводим команду вывести список звуковых карт и видим, что профиль headset_head_unit активирован
pacmd list-cards
Узнать активные профили
Дальше в /etc/pulse/client.conf добавляю к default-server =
autospawn = no
Сохраняю, выхожу из root и перезапускаю pulseaudio командой
Захожу в Home Assistant в терминал SSH & Web Terminal и ввожу
ha audio info
никаких устройств нет
далее ввожу и вижу свои bluetooth наушники Sony DR-BT50 у которых активирован профиль A2DP, а профиль headset_head_unit деактивирован
pactl list cards
Перезапускаю ha audio командой, вижу, то активирован профиль A2DP
ha audio reload
And so, many hours of attempts to make the bluetooth microphone work were unsuccessful. I even installed Debian 11 on a virtual machine, installed a portainer and deployed a Rhasspy container with such parameters. There are only built-in sound cards, but there is no usb bluetooth headset. As they say, for the bluetooth headset to work in Rhasspy Assistant, you need to install bluez-alsa on Debian, but I can’t install and run bluez-alsa, even if I just compile according to this instructions, there are no necessary packages for Debian 10 and 11, which also need to be built.
version: "3.8"
services:
  rhasspy:
    image: rhasspy/rhasspy
    container_name: rhasspy
    privileged: true
    network_mode: bridge
    restart: unless-stopped #always
    ports:
      - 12101:12101 #http
      - 12183:12183 #mqtt
    devices:
      - /dev/snd/*
    volumes:
      - /home/docker/rhasspy/profiles:/profiles
      - /etc/localtime:/etc/localtime:ro
      - /home/docker/rhasspy/.config/pulse/cookie:/home/rhasspy/.config/pulse/cookie
      - /run/user/1000/pulse:/run/user/1000/pulse
      - /home/docker/rhasspy/pulseaudio:/etc/pulse/client.conf.d
    command: --user-profiles /profiles --profile ru
    environment:
      - PULSE_SERVER=unix:/run/user/1000/pulse/native
      - PULSE_RUNTIME_PATH=/run/user/1000/pulse
As a result, I just took a radio microphone and a portable speaker with which it works perfectly.
It works through the Rhasspy Assistant addon
In order for the bluetooth speaker to work, you need to add in /etc/pulse/client.conf
autospawn = no
