How to transfer value from Home Assistant input_text helper to CCS811 sensor Baseline?
Hi.
Is it possible to use input_text helper value from Home Assistant as CCS811 sensor Baseline value in ESPHome device?
Slice of my ESPHome device code:
  - platform: homeassistant
    entity_id: input_text.ccs811_baseline
  - platform: ccs811
    eco2:
    tvoc:
    address: 0x5A
    baseline: id(ccs811_baseline_input).state | int(base=16)   # <-- This should to be set same value that "input_text.ccs811_baseline" contain.
    temperature: bme280_temp
    humidity: bme280_hum
baseline: !lambda... see docs for lambda.
If that does not work, then that input is not lambda-enabled.
From the CCS811 documentation, can see that baseline is not templatable. So, can only configure a static value here.
Thanks for you both.
Here’s my current Baseline code:
baseline: !lambda "return id(ccs811_baseline_input).state | int(base=16);"
Yes… it seems that trying to use lambda in Baseline will cause an error, like CK Smart said:
It would have been handy to be able update Baseline without updating and rewriting code…
