How to: Transparent Slider button card?
At the moment I’m working on ‘optimizing’ (like it ever ends…) the frontend of the dashboard in the living room. So far so good but I"m struggling with the slider-button-card. I try to make it transparent, just like the other buttons (see picture), but cannot find the correct code entry to change it.
The problem is that, when in ‘off’ state, the slider buttons are dark black/blue. The top two sliders in the picture are in the ‘off’ state and the bottom two are ‘on’. The slider itself (to show brightness) is also transparent, but I’ll try to fix that later.
I’m using the blue-red theme of the ios-themes (by basnijholt, see github). Until now I’ve changed basically every color entry to ‘transparent’ in both the ios-theme yaml and slider button js files, but it does not show up transparent. What am I missing?
The code of the two files are posted below.
Thanks!! Bas
The ios-themes code that is currently active:
# iOS Dark Mode Theme - blue-red
ios-dark-mode-blue-red:
  # Global
  background-image: "center / cover no-repeat fixed url('/hacsfiles/themes/ios-themes/homekit-bg-blue-red.jpg')"
  lovelace-background: var(--background-image)
  primary-color: transparent  # from Apple systemOrange dark mode
  light-primary-color: "#B6B6C1"  # (icons on left menu) (light: systemGray5 from iOS dark mode, dark: XXX)
  primary-background-color: "#2c2c2e"  # systemGray5 dark mode
  secondary-background-color: rgba(25, 25, 25, 0.9)
  divider-color: rgba(152, 152, 157, 0.3)  # from Apple systemGray dark mode
  accent-color: rgba(255, 159, 9, 1)
  # Text
  primary-text-color: "#FFF"
  secondary-text-color: "#d3d3d3"
  text-primary-color: "#FFF"
  disabled-text-color: "#555"  # XXX: https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/2
  text-dark-color: "#FFF"
  # Sidebar Menu
  sidebar-background-color: var(--primary-background-color)
  sidebar-icon-color: var(--light-primary-color)
  sidebar-text-color: "#F1F1F1"
  sidebar-selected-background-color: var(--primary-background-color)
  sidebar-selected-icon-color: "#FFF"  # (light: systemGray5 from iOS light mode, dark: XXX)
  sidebar-selected-text-color: var(--sidebar-selected-icon-color)
  # States and Badges
  state-icon-color: "#FFF"
  state-icon-active-color: rgba(255, 214, 10, 1)  # or make light icons yellow when active: rgba(255, 214, 10, 1)
  state-icon-unavailable-color: var(--disabled-text-color)
  paper-item-icon-active-color: rgba(255, 214, 10, 1)  # see https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/30
  # Sliders
  paper-slider-knob-color: "#FFFFFF"
  paper-slider-knob-start-color: var(--paper-slider-knob-color)
  paper-slider-pin-color: var(--paper-slider-knob-color)
  paper-slider-active-color: "#0984ff"  # from Apple systemBlue dark mode
  paper-slider-secondary-color: var(--paper-slider-knob-color)
  paper-slider-container-color: rgba(255, 255, 255, 0.5)
  paper-slider-font-color: "#000"
  ha-slider-background: none !important
  # Labels
  label-badge-background-color: "#23232E"
  label-badge-text-color: "#F1F1F1"
  label-badge-red: rgba(255, 159, 9, 0.7)  # from Apple systemOrange dark mode
  # Cards
  card-background-color: var(--secondary-background-color)  # Unused entities table background
  paper-listbox-background-color: var(--primary-background-color)
  ha-card-border-radius: 20px
  ha-card-background: transparent
  paper-card-background-color: var(--ha-card-background)
  ha-card-border-width: 0  # https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/82#event-7732695357
  # Toggles
  paper-toggle-button-checked-button-color: "#484848"
  paper-toggle-button-checked-bar-color: "#484848"
  paper-toggle-button-unchecked-button-color: var(--paper-toggle-button-checked-button-color)
  paper-toggle-button-unchecked-bar-color: var(--disabled-text-color)
  # Table row
  table-row-background-color: var(--primary-background-color)
  table-row-alternative-background-color: var(--secondary-background-color)
  # Switches
  switch-checked-color: "#30d257"  # XXX: remove when https://github.com/home-assistant/home-assistant-polymer/pull/4203 is in HA
  switch-checked-track-color: "#30d158"  # from Apple systemGreen dark mode
  switch-checked-button-color: "#FFF"
  # Other
  paper-dialog-background-color: rgba(55, 55, 55, 0.8)  # e.g., background of more-info
  paper-item-icon-color: white  # also should mini-media-player icon white (but doesn't work by itself)
  more-info-header-background: rgba(25, 25, 25, 0.5)
  lumo-body-text-color: var(--primary-text-color)  # see https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/42
  app-header-background-color: rgba(30, 2, 61, 0.4)
  markdown-code-background-color: "#464646"
  code-editor-background-color: "#161616"
  # Custom
  mcg-title-letter-spacing: .15em
  mini-media-player-base-color: white
  mini-media-player-icon-color: white
  # Added for https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/72
  # TODO: add description for lines below. Suggested in https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/72
  input-ink-color: var(--primary-text-color)
  input-fill-color: transparent
  input-disabled-fill-color: transparent
  input-label-ink-color: var(--primary-text-color)
  input-disabled-ink-color: var(--disabled-text-color)
  input-dropdown-icon-color: var(--primary-text-color)
  input-idle-line-color: var(--secondary-text-color)
  input-hover-line-color: var(--secondary-text-color)
  codemirror-property: var(--accent-color)
The part of code in the slider-button-card that I think is relevant (maybe not, let me know):
    ha-card {
      box-sizing: border-box;
      height: 100%;
      width: 100%;
      min-height: 7rem;
      display: flex;
      flex-direction: column;
      justify-content: space-between;
      touch-action: pan-y;
      overflow: hidden;
      --mdc-icon-size: 2.2em;
    ha-card.square {
      aspect-ratio: 1 / 1;
    ha-card.compact {
      min-height: 3rem !important;
    :host {
      --slider-bg-default-color: var(--primary-color, rgb(95, 124, 171));
      --slider-bg: var(--slider-color);
      --slider-bg-filter: brightness(100%);
      --slider-bg-direction: to right;
      --slider-track-color: #2b374e;
      --slider-tracker-color: transparent;
      --slider-value: 0%;
      --slider-transition-duration: 0.2s;
      /*--label-text-shadow: rgb(255 255 255 / 10%) -1px -1px 1px, rgb(0 0 0 / 50%) 1px 1px 1px;*/
      /*--label-color-on: var(--primary-text-color, white);*/
      /*--label-color-off: var(--primary-text-color, white);*/
      --icon-filter: brightness(100%);
      --icon-color: var(--paper-item-icon-color);
      --icon-rotate-speed: 0s;
      /*--state-color-on: #BAC0C6; */
      /*--state-color-off: var(--disabled-text-color);*/
      /*--state-text-shadow: rgb(255 255 255 / 10%) -1px -1px 1px, rgb(0 0 0 / 50%) 1px 1px 1px;*/
      --btn-bg-color-off: rgba(43,55,78,1);
      --btn-bg-color-on: #20293c;
      /*--action-icon-color-on: var(--paper-item-icon-color, black);*/
      /*--action-icon-color-off: var(--paper-item-icon-color, black);*/
      /*--action-spinner-color: var(--label-badge-text-color, white);*/
    /* --- BUTTON --- */
    .button {
      position: relative;
      padding: 0.8rem;
      height: 100%;
      min-height: 7rem;
      width: 100%;
      display: block;
      overflow: hidden;
      transition: all 0.2s ease-in-out;
    ha-card.compact .button {
    .button.off {
      background-color: var(--btn-bg-color-off);
    /* --- ICON --- */
    .icon {
      position: relative;
      cursor: pointer;
      width: var(--mdc-icon-size, 24px);
      height: var(--mdc-icon-size, 24px);
      padding: 0;
      outline: none;
      animation: var(--icon-rotate-speed, 0s) linear 0s infinite normal both running rotate;
      -webkit-tap-highlight-color: transparent;
    .icon ha-icon {
      filter: var(--icon-filter, brightness(100%));
      color: var(--icon-color);
      transition: color 0.4s ease-in-out 0s, filter 0.2s linear 0s;
    .icon.has-picture {
      background-size: cover;
      border-radius: 50%;
    .icon.has-picture ha-icon{
      display: none;
    .unavailable .icon ha-icon {
      color: var(--disabled-text-color);
    .compact .icon {
      float: left;
    /* --- TEXT --- */
    .text {
      position: absolute;
      bottom: 0;
      left: 0;
      padding: 0.8rem;
      pointer-events: none;
      user-select: none;
      font-size: 1.1rem;
      line-height: 1.3rem;
      max-width: calc(100% - 2em);
      /*text-shadow: rgb(255 255 255 / 10%) -1px -1px 1px, rgb(0 0 0 / 50%) 1px 1px 1px;*/
    .compact .text {
      position: relative;
      top: 0.5rem;
      left: 0.5rem;
      display: inline-block;
      padding: 0;
      height: 1.3rem;
      width: 100%;
      overflow: hidden;
      max-width: calc(100% - 4em);
    .compact.hide-action .text {
    /* --- LABEL --- */
    .name {
      color: var(--label-color-on, var(--primary-text-color, white));
      text-overflow: ellipsis;
      overflow: hidden;
      white-space: nowrap;
      text-shadow: var(--label-text-shadow, none);
    .off .name {
      color: var(--label-color-off, var(--primary-text-color, white));
    .unavailable.off .name,
    .unavailable .name {
    .compact .name {
      max-width: calc(100% - 3.5em);
    /* --- STATE --- */
    .state {
      color: var(--state-color-on, var(--label-badge-text-color, white));
      text-shadow: var(--state-text-shadow);
      transition: font-size 0.1s ease-in-out;
    .changing .state {
      font-size: 150%;
    .off .state {
      color: var(--state-color-off, var(--disabled-text-color));
    .unavailable .state {
    .compact .state {
      max-width: calc(100% - 0em);
      overflow: hidden;
    /* --- SLIDER --- */
    .slider {
      position: absolute;
      top: 0px;
      left: 0px;
      height: 10%0;
      width: 100%;
      background-color: var( --ha-card-background, var(--card-background-color, var(--btn-bg-color-on, black)) );
      cursor: ew-resize;
      z-index: 0;
    .slider[data-mode="bottom-top"] {
      cursor: ns-resize;
    .slider[data-mode="top-bottom"] {
      cursor: ns-resize;
    .slider:active {
      cursor: grabbing;
    /* --- SLIDER OVERLAY --- */
    .slider .toggle-overlay {
      position: absolute;
      top: 0px;
      left: 0px;
      height: 100%;
      width: 100%;
      cursor: pointer;
      opacity: 1;
      z-index: 999;
    /* --- SLIDER BACKGROUND --- */
    .slider-bg {
      position: absolute;
      top: 0;
      left: 0px;
      height: 100%;
      width: 100%;
      background: var(--slider-bg);
      background-size: var(--slider-bg-size, 100% 100%);
      background-color: var(--slider-bg-color, transparent);
      background-position: var(--slider-bg-position, 0 0);
      filter: var(--slider-bg-filter, brightness(100%));
    .off .slider .slider-bg {
      background-color: var( --ha-card-background, var(--card-background-color, var(--btn-bg-color-off, black)) );
    .slider[data-background="solid"] .slider-bg {
      --slider-bg-color: var(--slider-color);
    .slider[data-background="triangle"] .slider-bg {
      --slider-bg-direction: to bottom right;
      --slider-bg: linear-gradient(var(--slider-bg-direction), transparent 0%, transparent 50%, var(--slider-color) 50%, var(--slider-color) 100%);
      border-right: 0px solid;
    .slider[data-background="triangle"][data-mode="bottom-top"] .slider-bg {
      --slider-bg-direction: to top left;
    .slider[data-background="triangle"][data-mode="top-bottom"] .slider-bg {
      --slider-bg-direction: to bottom left;
    .slider[data-background="custom"] .slider-bg {
      --slider-bg: repeating-linear-gradient(-45deg, var(--slider-color) 0, var(--slider-color) 1px, var(--slider-color) 0, transparent 10%);
      --slider-bg-size: 30px 30px;
    .slider[data-background="gradient"] .slider-bg {
      --slider-bg: linear-gradient(var(--slider-bg-direction), rgba(0, 0, 0, 0) -10%, var(--slider-color) 100%);
    .slider[data-background="striped"] .slider-bg {
      --slider-bg: linear-gradient(var(--slider-bg-direction), var(--slider-color), var(--slider-color) 50%, transparent 50%, transparent);
      --slider-bg-size: 4px 100%;
    .slider[data-background="striped"][data-mode="bottom-top"] .slider-bg,
    .slider[data-background="striped"][data-mode="top-bottom"] .slider-bg {
      --slider-bg-size: 100% 4px;
    .slider[data-mode="bottom-top"] .slider-bg {
      --slider-bg-direction: to top;
    .slider[data-mode="top-bottom"] .slider-bg {
      --slider-bg-direction: to bottom;
    /* --- SLIDER THUMB --- */
    .slider-thumb {
      position: relative;
      width: 100%;
      height: 100%;
      transform: translateX(var(--slider-value));
      background: transparent;
      transition: transform var(--slider-transition-duration) ease-in;
    .changing .slider .slider-thumb {
      transition: none;
    .slider[data-mode="top-bottom"] .slider-thumb {
      transform: translateY(var(--slider-value)) !important;
    .slider[data-mode="bottom-top"] .slider-thumb {
      transform: translateY(calc(var(--slider-value) * -1))  !important;
    .slider-thumb:before {
      content: '';
      position: absolute;
      top: 0;
      left: -2px;
      height: 100%;
      width: 2px;
      background: var(--slider-color);
      opacity: 0;
      transition: opacity 0.2s ease-in-out 0s;
      box-shadow: var(--slider-color) 0px 1px 5px 1px;
      z-index: 999;
    .slider[data-mode="top-bottom"] .slider-thumb:before {
      top: -2px;
      left: 0px;
      height: 2px;
      width: 100%;
    .changing .slider-thumb:before {
      opacity: 0.5;
    .off.changing .slider-thumb:before {
      opacity: 0;
    .slider-thumb:after {
      content: '';
      position: absolute;
      top: 0;
      left: 0px;
      height: 100%;
      width: 100%;
      background: var( --ha-card-background, var(--card-background-color, var(--btn-bg-color-on, black)) );
      opacity: 1;
    .slider[data-show-track="true"] .slider-thumb:after {
      opacity: 0.9;
    .off .slider[data-show-track="true"] .slider-thumb:after {
      opacity: 1;
    /* --- ACTION BUTTON --- */
    .action {
      position: relative;
      float: right;
      color: var(--action-icon-color-on, var(--paper-item-icon-color, black));
      cursor: pointer;
      outline: none;
    .action ha-switch {
      position: absolute;
      right: 0;
      top: 5px;
    .off .action {
      color: var(--action-icon-color-off, var(--paper-item-icon-color, black));
    .unavailable .action {
    .circular-loader {
      position: absolute;
      left: -8px;
      top: -8px;
      width: calc(var(--mdc-icon-size, 24px) + 16px);
      height: calc(var(--mdc-icon-size, 24px) + 16px);
      opacity: 0;
      transition: opacity 0.2s ease-in-out;
      animation: rotate 2s linear infinite;
    .action.loading .circular-loader {
      opacity: 1;
    .loader-path {
      fill: none;
      stroke-width: 2px;
      stroke: var(--action-spinner-color, var(--label-badge-text-color, white));
      animation: animate-stroke 1.5s ease-in-out infinite both;
      stroke-linecap: round;
    /* --- MISC --- */
    .unavailable .slider .toggle-overlay,
    .unavailable .action,
    .unavailable .action ha-switch,
    .unavailable .slider {
      cursor: not-allowed !important;
    @keyframes rotate {
      100% {
        transform: rotate(360deg);
    @keyframes animate-stroke {
      0% {
        stroke-dasharray: 1, 200;
        stroke-dashoffset: 0;
      50% {
        stroke-dasharray: 89, 200;
        stroke-dashoffset: -35;
      100% {
        stroke-dashoffset: -124;
    `}};t([Zt({attribute:!1})],kr.prototype,"hass",void 0),t([Kt()],kr.prototype,"config",void 0),t([Jt(".state")],kr.prototype,"stateText",void 0),t([Jt(".button")],kr.prototype,"button",void 0),t([Jt(".action")],kr.prototype,"action",void 0),t([Jt(".slider")],kr.prototype,"slider",void 0),t([te({passive:!0})],kr.prototype,"onPointerDown",null),t([te({passive:!0})],kr.prototype,"onPointerUp",null),t([te({passive:!0})],kr.prototype,"onPointerMove",null),kr=t([Yt("slider-button-card")],kr);export{kr as SliderButtonCard};
Maybe relevant: my default theme is the ‘noctis’ theme which is dark black/blue-ish. This is also the color that the slider button shows in the ‘off’ state. So this also seems to be connected somehow.
Hope somebody can help :slight_smile:
