How to trigger a camera snapshot using only ESPHome?
Hi everyone,
first post here, looking for a clue on how to trigger a camera snapshot entirely with ESPHome not using HomeAssistant.
I am building a radar (mmWave, LD2410) based home surveillance system. The LD2410 works great with ESPHome, absolutely marvelous.
Additionally to triggering the radar output and sending a Telegram message (working already), I want to upload a camera image. I will be using an Ethernet board; right now I am working with this: https://www.tindie.com/products/allexok/esp32-stick-poe-a-camn16r8/.
The hardware side is working well.
My question is:
How can I trigger a camera snapshot, when the motion switch/toggle from the LD2410 sensor gets activated?
Can I use an automation?
The aim is to either
  • send the image via telegram (or ntfy.sh etc.)
    or
    -upload it to a most simple web server component (not preferred, I would like to keep the setup as simple and independent as possible).
Thank you very much for any hints,
Joost
Edit, summing up working and planned steps:
  • working: ESP32 camera board, powered via PoE, LD2410 mmWave radar sensor connected
  • working: Sending a Telegram message when the mmWave sensor detects motion
  • working: camera componenet and camera_server; I can receive the stream via IP:8080 in a browser
  • to be done: Trigger a camera snapshot
  • to be done: Send the snapshot via Telegram or another notification service or (less preferred) upload it to a simple server component
Hi there,
anyone with an idea on how to approach this?
Thanks for any help!
