How to trigger an automation based on this log event
I want to create an automation based on successful logins the Supervisor log.
2024-04-30 07:20:00.467 INFO (MainThread) [supervisor.auth] Successful login for 'myuser'
I have deduced that the trigger should be event with event type system_log_event but not sure how to write the condition logic to target successful logins with my user.
Example code I found for automations based on log events:
alias: example 555
- platform: event
  event_type: system_log_event
condition: '{{ "zwave_js_server.exceptions.Failed" in trigger.event.data.exception }}'
- service: notify.notifier_telegram
    message: 'Zwave Error 2'
It could look something like this
alias: example 555
- platform: event
  event_data:
    level: INFO
condition:
  - condition: template
    value_template: "{{ 'Successful login for ''myuser''' in trigger.event.data.message }}"
Hmm, doesnt seem to trigger
Take name or level or both out of event_data. You should get too many triggers, but you will be able to see in the traces the correct values to filter on.
