Is it possible to trigger an automation when a entity receives ON when ON or OFF when OFF?
I want to add functionality to my wall switch (433Mhz switch rx via RFLink) so that I can turn on the switch for the speaker in the room by pressing the button to turn off the ceiling light when the ceiling light is off.
Triggering the entity to change from OFF to OFF or null to OFF does not work.
alias: Speaker
description: Turn on speaker
- platform: state
entity_id:
- switch.gastrum_wall_switch
to: "off"
condition: []
- service: switch.turn_on
data: {}
entity_id: switch.gastrum_speaker
mode: single
Edit:
Information that I should have written in this first post to make it more clear was:
I want to turn on the speaker without affecting the state of the ceiling lamp but using same button.
This is an Event Trigger. It triggers when it detects a button_pressed event and the event’s data includes a reference to entity_id with a value of switch.gastrum_wall_switch.
Unless the event’s data contains more information, like the entity’s state, there’s nothing else you can get from it.
You can go to Developer Tools > Events and enter button_pressed in the ‘Listen for event’ field, then click the ‘Start listening’ button. Proceed to press your wall switch and its associated event will be displayed (as well as any other button_pressed events produced within Home Assistant).
The displayed event’s data is what is accessible to an Event Trigger. If there’s no state information in the event’s data then it’s simply unavailable for use in an Event Trigger.
EDIT
Francisp has performed the experiment for you (see below). The result indicates state is included in the event so it’s possible to compare it to the switch entity’s current state value (see example below).
My 2cts, I have a number of RF switched that, when triggered go to ‘on’ (it receives ‘on’ only)
My automation sets the switch state to ‘off’ after each trigger
If, as Francis has presented, the state from the event represents the state being requested, then you should be able to use something like the following to cover both on and off.
What I mean is that it doesn’t matter if current state is ON or OFF for switch.gastrum_wall_switch. It will trigger when I press the OFF button regardless.
When switch.gastrum_wall_switch.state == OFF and I press OFF on that wall switch I want to trigger the action.
I don’t want to trigger the action when switch.gastrum_wall_switch.state == ON and I press OFF on that wall switch.
Your code doesn’t care about the previous state of the wall switch. It just checks if I press OFF and then triggers the action.
Your code is a good start because the state_changed action only fires on change and your triggers regardless. But the problem is that I want to trigger when there is a button press but not a state change. Are you with me?
Maybe I can have a state_changed trigger and a button_pressed trigger and only run the action if only the button_pressed trigger and not the other one?
