Hi! I am doing my first bigger automation for a ‘goodnight’ routine.
I want to run my speaker to play some rain sounds overnight when a) both phones are in the bedroom, b) both phones are charging, and c) it’s past 10:30pm.
I more or less got this working, but right now it seems the order in which the phones are placed is crucial for the automation to begin. I don’t want the automation to start until both phones are charging, but I also want it to start no matter which phone is placed on to charge first.
Can someone please let me know if I’m just doing it wrong, or if there is a better way of doing it? Or do I just need to double up and add both phones to the trigger and both phones to the wait-for-trigger?
P.S. Bonus points for anyone who knows why the looping of the media also doesn’t seem to work? Is there a way to loop the one hour audio file?
alias: Play rain sounds overnight
description: ''
# One phone placed charging
- platform: state
entity_id: sensor.iphone_ONE_battery_state
to: Charging
# Two phones must be in the bedroom (using room-assistant)
condition:
- condition: and
conditions:
- condition: state
entity_id: sensor.ONE_iphone_room_presence
state: bedroom-ra
- condition: state
entity_id: sensor.TWO_iphone_room_presence
state: bedroom-ra
# Must be between 10:30pm and before 6am
- condition: time
after: '22:30:00'
before: '06:00:00'
# Don't start automation until second phone begins to charge
- wait_for_trigger:
- platform: state
entity_id: sensor.iphone_TWO_battery_state
to: Charging
continue_on_timeout: false
# Lower volume of speaker
- service: media_player.volume_set
device_id: 57d870a7d52cdc5a780091aeb1ed158f
volume_level: 0.25
# Say goodnight
- service: tts.google_cloud_say
entity_id: media_player.bedroom_speaker
message: Good night!
cache: true
# Small delay to give enough time to wake speaker up and say goodnight
- delay:
hours: 0
minutes: 0
seconds: 6
milliseconds: 0
# Begin playing Google's rain sounds locally
- service: media_player.play_media
media_content_id: https://mydomain.com/local/audio/rain.mp3
media_content_type: music
# Set media to repeating so rain sounds continue to loop the entire night (one hour audio file)
- service: media_player.repeat_set
repeat: all
mode: single
I don’t have an answer about repeating the audio, but you should get rid of the “Wait for Trigger” and just use a template trigger that requires both phones to be charging. When the second phone’s state changes to charging, the template will return “True” and trigger the automation.
Ah I see. Thank you! Hopefully this makes it into the visual editor eventually with multiple sensors/values to choose instead of manually writing that code syntax.
Yeah, this was the brute force method I had for now haha. I know there’s a cleaner way, but it seems not using the visual editor just yet. Thanks for the reply!
Just realized a way to “loop” the audio without digging into scripting or making a bloated MP3 could be to just add a Wait for time to pass (delay) with 1 hour, and then call the same exact file again to play? Obviously would have to copy this 8 times for a full 8 hours, but I guess this will do until some looping functions are introduced for media play.
My two cents: waiting for an hour inside automation is not a good idea in case a restart of core (update, new custom integration, problems) you will loose automation state, it will not continue
You don’t need to use a “bloated mp3”… just create another automation that listens for the state of the media player to go from playing to idle and then calls your play_media service again. If restarts are an issue overnight, you could add a second trigger for that…
alias: Repeat rain sounds overnight
description: ''
- platform: homeassistant
event: start
- platform: state
entity_id: media_player.YOUR_PLAYER
to: 'idle'
condition:
- condition: state
state: 'idle'
- condition: time
after: '22:30:00'
before: '06:00:00'
mode: single
