I reinstalled Hass.io from scratch (updated from resinos to hassos) and at the same time I wanted to do a transition from traditional yaml to lovelace (including automations). And now everything works, except my car heater automation, where I want those automations to trigger X minutes BEFORE set time in UI. Basically, I set up time when I am going to leave from home in UI, and then, based on outdoor temperature (celcius), the car heater turns itself on 3, 2 or 1 hour before, like this:
If outdoor temperature is below -10, then turn on heater 3 hours before
If outdoor temperature is above -10 but below -5, then turn on heater 2 hours before
If outdoor temperature is above -5 but below 2, then turn on heater 1 hour before
With yaml automations I got this to work (using three different automations because I donāt know how I could put all those conditions in one automation), but now in Lovelace, where everything should be oh so smooth and easy I donāt seem to get this to work. I think itās because of my trigger that for some reason gets broken in Lovelace because it has several lines.
My trigger (in yaml) is:
value_template: >
{% set d = now().strftime("%m/%d/%Y ") %}
{% set t = strptime(d+states.sensor.alarm_clock3_time_long.state,"%m/%d/%Y %H:%M") %}
{{ states('sensor.time') == ( as_timestamp(t) - 180*60 )|timestamp_custom('%H:%M') }}`
And that used to work. That 180 * 60 means three hours, and I just had three of these (in three different automations), one had 120 * 60 and one had 60 * 60 respectively. But when I enter that in Lovelace automation in YAML mode, it switches to UI mode and then it looks like this (and yaml gets messed up as well):
So I think my problem is that I havenāt figured out how to put multiple lines in Lovelace automation trigger correctly But at the same time, I cannot help but think that it should be possible to do this automation a bit easier than using three different automationsā¦ And also that why donāt HASS support ānegative delayā? It would be so much easier just to use -3:00:00 in delay so that automation would trigger three hours before given timeā¦
I was thinking something like thisā¦just add the action and change the condition sensor to whatever outdoor temperature sensor you are using. Note, I havenāt tested this but it should get you going. If not, Iāll help out more tomorrow.
- alias: 'Turn Car on'
initial_state: on
platform: time_pattern
minutes: '/1'
seconds: '0'
condition:
condition: or
conditions:
- condition: template
value_template: >-
{% set temp = states.sensor.temperature.state %}
{% if states('sensor.time') == ( as_timestamp(t) - 180*60 )|timestamp_custom('%H:%M') and temp <= -10 %}true{%else%}false{% endif %}
- service: ...
Do I get it right that youāre trying to use Automation Editor and it does not allow you to achieve the result you could achieve previously by editing your automation.yaml? Iām using HA in Lovelace mode but change all my configs manually.
Why donāt you carry on with the latter?
Also, where are the three automations youāre talking about - I can only see one trigger. Do post them here.
And what is that sensor.alarm_clock3_time_long?
P.S I think this topic is more suitable to Configuration than to Hass.io
Good for you, but some less experienced members do not yet have this as an option, they need to get up to speed in their own way (though I do admit that it limits what assistance they can get as only a few members are battling with the new gui editors)
The OP asked for an example, that is what Jer78 provided, he also explained his concept. This is to allow the OP to compare what he asked for with the example, see how it is done and extend it. This is to help the OP grow. Itās often best not to give them a fish but show them how to fish.
AND yes you are right that this 'should have been under configuration, all new members should read the guidelines FAQ - Home Assistant Community but also (and more importantly in my book) the sticky by Tinkerer at the top of the forum.
Edit: though looking at his profile, heās been a member nearly as long as you (Mar 2018) everyone delelops at their own pace and some simply canāt devote that much time to a hobby.
Edit2: Though it would be nice if at the end of the solution the OP posted back the full automation as this shows that he has understood the advice given and itās there as a resource to the next guy.
It would also be very nice if he credited Jer78 with the solution (which is rarely the actual finished code, but the post that gave them the biggest clue to solving the problem)
Thanks for replies, I have been trying to get this to work without success. Also apologies if this went into wrong thread I have been here for a while, yes, but I set up all my automations back in the day and then left them as they were as everything worked perfect But now because I installed new version of Home Assistant and switched to SSD drive, and because I eventually decided to build everything up from scratch, I thought that using Lovelace in everything wasā¦ simpler and also preferred method of using HASS nowadays (no need to worry about formatting etc), but I guess thatās not the caseā¦
For me, this automation for my car heater is the only thing I cannot get to work. And it seems like now even my old code doesnāt work anymore when I just paste it into configuration.yaml. AhmadK, I had that sensor.alarm_clock3_time_long in my old code and it worked. But letās focus on my new code as itās tidier and the code that Jer78 kindly typed.
This is what I have in sensors now:
sensors:
alarm_clock3_time:
value_template: >
{% set h = states('input_number.alarm_clock3_hour') | int %}
{% set m = states('input_number.alarm_clock3_minute') | int %}
{{ '{0:0=2d}:{1:0=2d}'.format(h, m) }}
Then, this is the automation part, the code Jer78 provided (I gave in and put this in configuration.yaml, as it is much clearer compared to Lovelace automation when things are a bit complicated like in this automationā¦):
automation old: !include_dir_merge_list automations
automation old:
initial_state: on
minutes: '/1'
seconds: '0'
condition:
condition: or
conditions:
value_template: >-
{% set temp = states.sensor.sonoffth3_am2301_temperature.state %}
{% set t = strptime(d+states.sensor.alarm_clock3_time.state,"%m/%d/%Y %H:%M") %}
{% if states('sensor.time') == ( as_timestamp(t) - 180*60 )|timestamp_custom('%H:%M') and temp >= -10 %}true{%else%}false{% endif %}
- service: switch.turn_on
entity_id: switch.sonoffpow3_2
- delay: '03:00:00'
- service: switch.turn_off
I have to say that I have no clue about those time conversions and there is probably a simple reason why this automation never triggersā¦ Note that I changed condition for temperature to above -10 so it would trigger when I want (itās warmer than that now ).
No, absolutely not. I was merely explaining why Jer78 did what he did and why it did not ātickā all your boxes. No blame to be placed, just an alternate perspective.
Okay, Jer78 is Canadian so heās probably at work now, give me 10 mins and Iāll sit down at a workstation. I can explain what I think can be optimised and what I think is redundant.
A couple of questions though : - you have two input numbers set up, one for hours and one for minutes - why ? - I mean you could just use an input datetime ? Then thereās the creation of this sensor in the first place (my own method would use a binary sensor but that was a completely different path and there are many ways to skin a cat) Jer78ās method sets an automation that fires every minute, tests conditions and then determines actions. You merely use you āset timeā in here.
How do you present this in your front end ?
Some people like to use input number sliders because itās easier when used from a phone (for instance) so your two input number 's may be valid for your usage.
Another point, say its -11 at -3hrs but itās -7 at -2hrs and -4 at -1hrs - what do you think should happen ?
Oh and does this only run on weekdays?
Hereās how it looks like in my front end (or the idea, I will clean it later when it works ):
So yes, thatās why I use two input numbers. I set time when I want to leave home, and then automation warms up my car as needed beforehand. As for creating the sensor, I thought thatās what needs to be done so I can form time from hour and minute values? And then I could use alarm_clock3_time for something else as well if needed.
I am not 100% sure I understand why automation needs to be fired every minute (well, I guess it isnāt as like you said, there are many ways to skin a cat ), but if I have understood right, somehow using that method I can get by using only one automation instead of three that I used to have (1: start heater 3 hours earlier if temperature is below -10, 2: start heater 2 hours earlier if temperature is between -10 and -5 and 3: start heater 1 hour earlier if temperature is between -5 and +2)? That would be great
This is meant to run whenever I want, not only weekdays, earlier I just toggled automation on or off as needed. As for your point about if temperature changes like thatā¦ Yes, earlier none of my three automations fired in case of your scenario, but luckily that didnāt happen often
Oh, thank you petro! I donāt know how I didnāt find THAT thread since OP there wants to do exactly the same as me, but maybe thatās because I started to search for Lovelace solutionsā¦
And I am sure there are many different ways to solve this problem, but to me they all seem overly complicated considering that itās pretty simple thing I want to achieve, just trigger something early based instead of delayed, and I thought as time has passed, Lovelace introduced quite a while back already etc etc, that there would be some simple solution to this kind of problem already that I just wasnāt aware of Well, maybe one day there will be ānegative delayā in HASS out-of-box
Anyway, I am going to read that thread now and return back if (and hopefully when!) I get my automation working.
What you want to do is not simple. Anytime you want to do something dynamically in any software package, it changes the process from simple to complex.
All right, I have tried pretty much everything here and although configuration seems always to be okay, the automation just does not trigger. So I figured out I should use template editor and test those things that I suspect might cause problems. I ended up using code that @Jer78 gave because that seems to give right values for me, for example this template here:
value_template: >-
I get right values from every variable until last line. see here:
Now, when sensor.time is exactly three hours before set time (that is, when this automation should trigger), template editor just returns āunknown error rendering templateā. When that minute passes, template shows values again. So I think thereās something wrong with that if-statement but I have no idea what it isā¦
All right, I have some errors in my logs but I assume thatās because of one binary sensor experiment still active (that error fires off once every minute). I will comment that part out, and probably everything else regarding this as well, as I am quitting for today I think 80 ways to do this and I cannot get even one way to work, greatā¦
Spacing was off only in my post, in configuration.yaml it is right.
I tried that value_template provided by @petro but that gives strange error when I try to validate my code. It says: "Invalid config for [automation]: invalid template (TemplateSyntaxError: unexpected ā}ā, expected ā)ā) for dictionary value @ data[ātriggerā][0][āvalue_templateā]. Got None. (See /config/configuration.yaml, line 230). "
Well, on line 230 there is nothing but empty line When I comment out those three lines under that value_template, then my code is valid again. But those rows are on lines 262-264ā¦
