I have a device (a select input for presence checks, since I like to manually control this).
When the input_select is set to Sleeping or Home some automations trigger. If the devices current state is already Sleeping and I set it to Sleeping again, nothing is triggered.
I want it to trigger the automation even when the state is changed to the same value. How can I do this?
One of the two automations currently looks like this. It works as long as there was an actual state change, like for Sleeping to Awake. The Automation gets triggered by any state change of the input_select and then has some logic to decide what should happen, using the value_template.
alias: tim_status_after_sunset
description: ""
- platform: state
entity_id:
- input_select.tim_home_status
condition:
- condition: sun
after: sunset
before: sunrise
- choose:
- conditions:
- condition: template
value_template: "{{ trigger.to_state.state == \"Zuhause\" }}"
sequence:
- service: scene.turn_on
entity_id: scene.alle_tim_home_sundown
metadata: {}
alias: if new state is "Zuhause"
- conditions:
value_template: "{{ trigger.to_state.state == \"Schlafen\" }}"
sequence:
entity_id: scene.alle_tim_sleep_lights
metadata: {}
- service: climate.set_temperature
device_id:
- 89a37f3f414064c9a0d8e4b50f95b263
- c0556c523c769081aa822cf37e9ae53a
- c8011feb23fea7909b57dbfff5ddac6e
temperature: 4
alias: if new state is "Schlafen"
mode: single
But that wont fix your issue anyway, so the state trigger will only trigger on change. What u want would be an event, for example the service call input_select.select_option is something you might want as trigger.
Specifically, how are you “setting” the Input Select to the same state it currently has. It cannot be done via the UI without first changing it to another value so I am interested to know how you’re setting the same state. Perhaps via a service call?
I created a helper “button” that is triggered by an Alexa command and, in turn, triggers an automation to set the input_select to the respective state.
It sounds like you need to have an additional “mode” so you have something to switch from and to. I have a fairly elaborate system for this that drives a LOT of my automations (i.e., don’t send TTS messages if not awake, etc). Even something like “Still Sleeping” that automation changes immediately to “Sleeping”.
For me I have states like:
Sleeping
Awake
One Awake (one of is up, the other is not)
Napping
DND
Can you explain the reasoning behind wanting to set your sleep mode to sleeping when it’s already sleeping? That might inspire some suggestions on how you could improve upon it.
So, via service call input_select.select_option in a separate automation.
Why not simply modify your automation (the one posted above) to monitor the Button’s state (in a State Trigger)?
When it triggers, your automation should handle it like if the Input Select had been set to Sleeping. This can be easily achieved by enhancing the choose’s second condition (the one handling Schlafen) .
- platform: state
entity_id:
- button.your_button
Mostly out of convenience. Say you set the state to sleep, but get up again and change a few lights by voice command or Hue remote, and get back to bed, I like to just say my sleep command again to trigger the automations instead of manually setting each device back to the “sleep” state.
I just moved from Fhem to HA, and this is how it worked there. I am fairly new to HA, so maybe I will create an automation-script that will do the logic (similiar to what you described) and just call that upon button press.
I think just adding a bit more logic to the automation that listens for the Alexa-helper button and adding an “intermediate” state for the input_select, which gets briefly selected and changed back if the desired state is already set, should do the trick for now.
That’s a good example of using your “sleep mode” (as I call it on mine) to control lights. You say when you are awake then perhaps those lights stay on 15 minutes, but when the mode is sleeping it stays on for 3 minutes. Even get extra fancy with it and say if I detect motion a second time then make it stay on 10 minutes.
You can make your smart home pretty smart with HA, you just have to think about what you need to achieve. I try to work on the “90% rule” that says I build a system for 90% of the needs with 10% being the out-of-the-ordinary stuff I’ll handle as I need to. Do you get up a lot after going to bed (I do)? If so then build automation that supports that in, again, a “90% of the time when I get up after going to bed I need this to happen” approach.
