Hello this is my first post on this forum.
I installed home-assistant core (2020.12.0) on a Ubuntu 20.04 Proxmox container. It works. I am amazed since then of all the possibilities of HA what an great piece of software.
I created my first simple automation after the first week fiddling around in HA and it even works haha I never thought i would pickup this level already this fast.
Now i have kind of impossible thing i want to try, maybe someone can help.
I have a Hikvision camera hooked up to HA i also have a Philips HUE lighting systeem hooked up with several in and outdoor motion sensors.
Since my Hikvision outdoor camera does not have a PIR sensor and my HUE outdoor sensor does have PIR i figured maybe i can use the HUE motion sensor to start the Camera to start to record.
I added a guest user with right to view live stream and the right to start a remote record.
What is the next step? How do i make HA to start a record after motion is detected. In HA i see the HUE motion detections that part works. The camera is also hooked up alright because i see the camera VCA detections also. The camera records onto a 64gb sd card inside the camera.
The hikvision camera detects motion based on what happens in the view specialy at night it doesn;t pick up motion that well. The HUE motion sensor works a lot better in the dark so it would be great if i could use the HUE motion detection to start the camera to record.
Thank you for reading.
I was using following on Vera Hub
ācurl -v -X PUT -u user:pass -H āContent-Type: application/jsonā http://ip_address/ISAPI/ContentMgmt/record/control/manual/start/tracks/101ā For start record
ācurl -v -X PUT -u user:pass -H āContent-Type: application/jsonā http://ip_address/ISAPI/ContentMgmt/record/control/manual/start/tracks/101ā For stop record
Basically this are post rest requests you can adapt them to HA .
In HA i record the cameras directly on home assistant disk
P.S. Not all models support http requests for recording
That looks promising. Iāam going to figure out if my camera can do this. Now i have a direction how this might work. Thank you
Hi @Miki_Krstevski tonight i tested what you advised and it works right away the first try, great!
Do you or someone else can tell me how i go from here to the next step? Now i know how to remotely start and stop the camera recording. I have the HUE motion sensor in HA how do i start the video recording, the start command wen the HUE sensor detects motion?
Never mind its working now.
I added this in configuration.yaml
shell_command:
cam2_record_start: "curl -v -X PUT -u user:pass -H 'Content-Type: application/json' http://ip_adress/ISAPI/ContentMgmt/record/control/manual/start/tracks/101"
cam2_record_stop: "curl -v -X PUT -u user:pass -H 'Content-Type: application/json' http://ip_address/ISAPI/ContentMgmt/record/control/manual/stop/tracks/101"
After that i created 2 automations one for: cam2_record_start
And one for: cam2_record_stop
