How to trigger.to_state inside a script help
Having the trigger.to_state within the automation works. However, it does not work if inside of a script. This error occurs. How to rewrite the code inside the script?
Door Family Greetings: Error executing script. Error for call_service at pos 1: Error rendering data template: UndefinedError: ‘trigger’ is undefined
This works:
- alias: announce who is arriving
     - platform: state
       entity_id:
        - input_boolean.duc_home
        - input_boolean.eri_home
       to: 'on'
    - service: notify.alexa_media
      data_template:
          type: tts
         - media_player.ai_1
        message: '{{ trigger.to_state.attributes.friendly_name }}, will be home in about 10 minutes.'
This does not work:
     - platform: state
       entity_id:
       to: 'on'
    - service: script.turn_on
        entity_id: script.door_family_greeting
script:
  door_family_greeting:
    alias: Door Family Greetings
    sequence:
        data_template:
            type: tts
          - media_player.ai_1
It doesn’t work for the simple reason that the Trigger State Object doesn’t exist outside the automation.
If you want the script to receive the Trigger State Object’s value, you must pass it as a variable to the script.
The procedure is explained here: Passing variables to scripts
Your automation will look something like this (the variable’s name can be whatever you want; I used the word person):
     - platform: state
       entity_id:
       to: 'on'
    - service: script.door_family_greeting
        person: "{{ trigger.to_state.attributes.friendly_name }}"
Your script will refer to the variable called person. For example:
    sequence:
        data_template:
            type: tts
          - media_player.ai_1
          message: '{{ person }}, will be home in about 10 minutes.'
Perfect explanation. Understood.
