The Troubleshoot Assist page shows good detail on how to see results of Assist runs.
My question is, how do I remotely access these? I would like to be able to monitor flows, either through an automation or using Node Red, but I have not been able to figure out how to access these debug pipelines.
My end goal is I would like to log the results of the STT, TTS, and commands issued so I can fine tune things.
I figured out a semi workaround, to see what the STT and TTS are; it doesn’t expose what device/s are changed.
Per the esphome documentation, a variable called “x” has the STT and TTS values at a specific point in the flow. I created variables for these and automations to store the values. Note that the variable X exists in the source code, but the compiler doesn’t know about it; I had to create a variable called X just to make it compile.
