If you shutdown the host, isn’t it going to send a signal to shutdown the core?
If you shutdown the core through the GUI then you lose GUI connection.
So, I would think all you would have to do is shutdown host.
FYI mine says “Shutdown system” (there is no “Shutdown core” or “Shutdown host”)
Running :
Home Assistant 2022.11.2
Supervisor 2022.10.2
Operating System 9.3
Frontend 20221108.0 - latest
Thanks! I was searching for this option for many time ago
omg, thank you so much. What ab obvious choice. Was looking for hours …
Although I believe -
sudo ha core stop
would do iit gracefully, I typically do this:
To stop Home Assistant Superviser from Autostarting:
sudo systemctl disable hassio-supervisor.service
sudo systemctl disable hassio-apparmor.service
then I reboot and do the maintenance work I need, then issue:
sudo systemctl enable hassio-supervisor.service
sudo systemctl enable hassio-apparmor.service
then I reboot again and check the logs etc.
Here is what I am running (64 bit Home Assistant Supervised (supported) running on a RPI 4 w/ 8Gigs of ram booting off a 1TB SSD installed with these steps - Installing Home Assistant Supervised on a Raspberry Pi with Debian 11 - #684 by KruseLuds):
System Information
version | core-2022.11.3 |
installation_type | Home Assistant Supervised |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.10.7 |
os_name | Linux |
os_version | 5.10.0-19-arm64 |
arch | aarch64 |
timezone | America/New_York |
config_dir | /config |
Home Assistant Community Store
GitHub API | ok |
GitHub Content | ok |
GitHub Web | ok |
GitHub API Calls Remaining | 4856 |
Installed Version | 1.28.3 |
Stage | running |
Available Repositories | 1210 |
Downloaded Repositories | 22 |
AccuWeather
can_reach_server | ok |
remaining_requests | 22 |
Home Assistant Cloud
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
Home Assistant Supervisor
host_os | Debian GNU/Linux 11 (bullseye) |
update_channel | stable |
supervisor_version | supervisor-2022.11.dev0401 |
agent_version | 1.4.1 |
docker_version | 20.10.21 |
disk_total | 915.4 GB |
disk_used | 13.0 GB |
healthy | true |
supported | true |
supervisor_api | ok |
version_api | ok |
installed_addons | Log Viewer (0.14.0), Samba share (10.0.0), Home Assistant Google Drive Backup (0.109.2), File editor (5.4.2), Duck DNS (1.15.0), Terminal & SSH (9.6.1), Core DNS Override (0.1.1), Mosquitto broker (6.1.3), AppDaemon (0.10.1), AdGuard Home (4.7.5) |
Dashboards
dashboards | 4 |
resources | 15 |
views | 25 |
mode | storage |
Recorder
oldest_recorder_run | October 20, 2022 at 5:25 AM |
current_recorder_run | November 17, 2022 at 10:54 AM |
estimated_db_size | 1594.20 MiB |
database_engine | sqlite |
database_version | 3.38.5 |
I’m running Core 2023.1.7 on a Raspberry Pi under Debian Bullseye.
There is no stop button anywhere that I can find. Not in Developer, System, anywhere.
How can I gracefully stop HA? I finally had to send a kill signal over ssh.
Settings > Hardware > Upper Right Corner (Power Button) if you hover of it it says restart, but there are choices just like Linux, Windows, Apple.
Thanks for the reply. No menu would load without an error image but I was still able to trigger switches from the app. I was reluctant to power down the host even with the very limited function but after trying everything within the app to figure out the issues, I just decided to plug the host from power. After plugging back in, it took a few minutes and after the restart appears to have come back normal. Prior to this, nothing was working and I’d already started researching how to restore from my back up image. Nothing like being throw into this situation and I haven’t practiced an emergency recover. I need to at least understand the process just in case I have to recover from a failure. I appreciate your help.
Craig
I’m new to HAOS, so pardon the stupid question:
I am running HAOS on a raspberry pi. If I choose “shut down the host system”, this gracefully shuts down Home Assistant prior to shutting down the host system, correct?
Could you provide a more complete thought? Instructions that start with ‘the button’ never go well. What button? I can’t find the shutdown or reboot using the instructions you provided. It seems like you’re in Settings > Hardware…
#2 seems un-followable. The first step is to click ''Configuration", I can’t find that. I have “Settings” but nothing under there called “Add-ons Backups and Supervisor”
Here’s complete working instructions to shutdown the system:
Settings > System > Power Icon in Upper Right Corner > Advanced Options > Shutdown System
Because the instructions were written a dozen versions ago; the location of menu items has changed.
Owing to Home Assistant’s rapid evolution, information in posts older than six months is likely to be outdated.
Personally -
press “c” while on any page of the dashboard. Type “system” and hit Enter.
Click the shutdown button in the top right of the system settings page.
Yeah sorry, I think I was meant to reply to the previous comment in the thread which provided the context.
Settings > System > Power Buttom (top right of UI)
Thank you!!! This solved my problems!
