I’d like my movement sensor to not respond when I’m sleeping. It’s really annoying when the lights turn on automatically. And I also don’t sleep at the same time so I can’t use the time feature. BTW I’m new with home assistant and I am still learning.
Is there a way for my automation, I couldn’t figure it out on my own.
My code that I used ( I juist created it with the UI but for you guys I wanted to just put in the code here):
<alias: 'Lampen aan wanneer iemand ''s avonds in mijn kamer is ' *(lights turn on when someone in the evening is in my room)*
description: ''
- type: motion
platform: device
device_id: cb94b1cec5b86b0d1f8706830f5e670a
entity_id: binary_sensor.bewegingssensor_occupancy
domain: binary_sensor
for:
hours: 0
minutes: 0
seconds: 0
milliseconds: 0
condition:
- condition: state
entity_id: sun.sun
state: below_horizon
- type: turn_on
device_id: d9499e90f72b48b0c9fb0ad0ba2153da
entity_id: light.lamp_1
domain: light
brightness_pct: 50
- type: turn_on
device_id: 3ccdeda492be66246d3e04d8d035439b
entity_id: light.lamp_2
domain: light
brightness_pct: 50
- type: turn_on
device_id: 31b7253e68a4b361608dba61b93d629f
entity_id: light.lamp_3
domain: light
brightness_pct: 50
mode: single>
I would create a template binary sensor “asleep”, and then use this sensor in your automations as a condition.
I set my sleep-sensor automatically through the sensors in the android companion app. If my phone is charging AND is in “do not disturb”-mode HA assumes I’m sleeping. Both conditions are never both true when I’m not sleeping.
But you might as well base the sensor on a boolean input and set it manually or through voice command.
@fiftys you are right, boolean input is just a work around, until he get’s appropriate sensors in place.
Adding the abstraction of the template sensor makes it easier to change things around without having to touch every automation again, that references the sleep-status
I think seanomat idea is great for now. But I’d like to add my phone battery state into a template and use that template to add it as a condition for when I charge my phone. But I don’t really know how to do it. This is the template what I’ve got for now. But on value template I need to fill in that it needs to read my battery state but I can’t figure out what to fill in exactly. Can someone help me out?
sensors: iphone_van_metehan_battery_state
friendly_name: Battery state
value_template:
Value template is where I’m stuck. I use the HA app and I can find the battery state data but I don’t know how to use it in this template.
