How to turn on speaker in esphome m5stack Atomic Echo Base
I have an Atom3SR paired with Atomic Echo Base
And I cannot turn on the speaker using esphome. I’m trying to use it as a voice assistant.
If I install the Atomic Echo Base XiaoZhi Voice Assistant the speaker works.
If I install my custom esphome yaml immediately after, the speakers continues to work, even in home assistant as a media device, but when I unplug the device from power and power it back on, the speaker stops working.
In home assistant I can still play media on it but no sound comes from the speaker, I believe it is turned off somehow and I don’t know how to turn it on.
I tried to replicate the commands in the xiaozhi-esp32 to esphome but I can’t turn the speaker on.
I tried to define a custom i2c_device
i2c_device:
   i2c_id: bus_b
   address: 0x43
and on button press to
      - logger.log: "Init echo base. id(test)"
      - lambda: !lambda |-
          id(test).write_byte(0x00, 0x07);
          id(test).write_byte(0xFF, 0x0D);
          id(test).write_byte(0x6E, 0x03);
          id(test).write_byte(0xFF, 0x05);
Here is the yaml, please ignore the extra code (for display,button etc.) and focus only on speaker and microphone.
Summary
substitutions:
  device_name: "AtomS3R"
  micro_wake_word_model: okay_nabu
esphome:
  friendly_name: ${device_name}
esp32:
  board: m5stack-atoms3
  variant: esp32s3
  framework:
    type: esp-idf
wifi:
  networks:
    - ssid: !secret wifi_ssid
  id:
    wifi_id
  ap:
logger:
api:
ota:
  - platform: esphome
    password: "111"
captive_portal:
improv_serial:
i2c:
  - id: bus_a
    sda: GPIO45
    scl: GPIO0
    scan: true
  - id: bus_b
    sda: GPIO38
    scl: GPIO39
    scan: true
i2c_device:
   i2c_id: bus_b
   address: 0x43
audio_dac:
  - platform: es8311
    bits_per_sample: 24bit
    sample_rate: 24000
    use_mclk: false
    i2c_id: bus_b
i2s_audio:
  - id: i2s_audio_bus
    i2s_lrclk_pin: GPIO6
    i2s_bclk_pin: GPIO8
microphone:
  - platform: i2s_audio
    i2s_din_pin: GPIO7
    adc_type: external
    pdm: false
speaker:
    i2s_dout_pin: GPIO5
    dac_type: external
    bits_per_sample: 32bit
    channel: left
    buffer_duration: 60ms
    audio_dac: es8311_dac
media_player:
  - platform: speaker
    announcement_pipeline:
      speaker: echo_speaker
      format: WAV
    codec_support_enabled: false
    buffer_size: 6000
    files:
      - id: timer_finished_wave_file
        file: https://github.com/esphome/wake-word-voice-assistants/raw/main/sounds/timer_finished.wav
voice_assistant:
  microphone: echo_microphone
  media_player: echo_media_player
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 2.0
  on_end:
    - delay: 100ms
    - script.execute: start_wake_word
  on_client_connected:
    - delay: 2s
  on_client_disconnected:
    - voice_assistant.stop:
  on_timer_finished:
    - wait_until:
        not:
          microphone.is_capturing:
lp5562:
  - i2c_id: bus_a
  - platform: mpu6886
    address: 0x68
    i2c_id: bus_a
    accel_x:
      name: "$device_name MPU6886 Accel X"
    accel_y:
      name: "$device_name MPU6886 Accel Y"
    accel_z:
      name: "$device_name MPU6886 Accel z"
    gyro_x:
      name: "$device_name MPU6886 Gyro X"
    gyro_y:
      name: "$device_name MPU6886 Gyro Y"
    gyro_z:
      name: "$device_name MPU6886 Gyro z"
    temperature:
      name: "$device_name MPU6886 Temperature"
  - platform: wifi_signal
    name: "WiFi Signal Sensor"
    update_interval: 120s
spi:
  clk_pin: GPIO15
  mosi_pin: GPIO21
color:
  - id: my_red
    red: 100%
    green: 0%
    blue: 0%
  - id: my_yellow
    red: 100%
    green: 100%
    blue: 0%
  - id: my_green
    red: 0%
    green: 100%
    blue: 0%
  - id: my_blue
    red: 0%
    green: 0%
    blue: 100%
  - id: my_gray
    red: 50%
    green: 50%
    blue: 50%
font:
  - file: "gfonts://Roboto"
time:
  - platform: homeassistant
switch:
    name: Use listen light
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    optimistic: true
    restore_mode: ALWAYS_OFF
    on_turn_off:
      - lambda: |-
          id(echo_media_player)
            ->make_call()
            .set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_REPEAT_OFF)
            .set_announcement(true)
            .perform();
          id(echo_media_player)->set_playlist_delay_ms(speaker::AudioPipelineType::ANNOUNCEMENT, 0);
      - media_player.stop:
          announcement: true
    on_turn_on:
      - lambda: |-
            ->make_call()
            .set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_REPEAT_ONE)
            .perform();
          id(echo_media_player)->set_playlist_delay_ms(speaker::AudioPipelineType::ANNOUNCEMENT, 1000);
      - media_player.speaker.play_on_device_media_file:
          media_file: timer_finished_wave_file
          announcement: true
      - delay: 15min
      - switch.turn_off: timer_ringing
display:
  - platform: ili9xxx
    model: ST7789V
    cs_pin: GPIO14
    dc_pin: GPIO42
    reset_pin: GPIO48
    rotation: 180
    invert_colors: true
    update_interval: 1s
    dimensions:
      height: 128
      width: 128
      offset_height: 1
      offset_width: 2
    lambda: |-
      it.rectangle(0,  0, it.get_width(), it.get_height(), id(my_blue));
      it.rectangle(0, 20, it.get_width(), it.get_height(), id(my_blue));
      it.strftime((128 / 2), (128 / 3) * 1 + 5, id(roboto_24), id(my_gray), TextAlign::CENTER, "%Y-%m-%d", id(esptime).now());
      it.strftime((128 / 2), (128 / 3) * 2 + 5, id(roboto_32), id(my_gray), TextAlign::CENTER, "%H:%M:%S", id(esptime).now());
      it.print(5, 5, id(roboto_12), id(my_yellow), TextAlign::TOP_LEFT, "ESPHome");
      if (id(wifi_id).is_connected()) {
        it.print(115, 5, id(roboto_12), id(my_green), TextAlign::TOP_RIGHT, "Online");
      else {
        it.print(115, 5, id(roboto_12), id(my_red), TextAlign::TOP_RIGHT, "Offline");
binary_sensor:
  - platform: status
  - platform: gpio
    pin:
      number: GPIO41
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
      - delayed_off: 10ms
    on_press:
      - logger.log: "Init echo base. id(test).read_byte"
    on_release:
text_sensor:
  - platform: wifi_info
    ip_address:
      name: ESP IP Address
    ssid:
      name: ESP Connected SSID
    bssid:
      name: ESP Connected BSSID
    mac_address:
      name: ESP Mac Wifi Address
    scan_results:
      name: ESP Latest Scan Results
    dns_address:
      name: ESP DNS Address
external_components:
  - source:
      type: git
      url: https://github.com/ssieb/esphome
      ref: lp5562
    components: [lp5562]
    refresh: 1min
output:
  - platform: lp5562
    channel: 0
  - platform: lp5562
    channel: 1
  - platform: lp5562
    channel: 2
  - platform: lp5562
    channel: 3
light:
  - platform: monochromatic
    output: white
    restore_mode: always_on
script:
  - id: start_wake_word
    then:
      - wait_until:
          and:
            - media_player.is_idle:
            - speaker.is_stopped:
      - if:
          condition: voice_assistant.is_running
          then:
            - delay: 1s
            - voice_assistant.start_continuous:
micro_wake_word:
  on_wake_word_detected:
    - voice_assistant.start:
        wake_word: !lambda return wake_word;
  vad:
  models:
    - model: ${micro_wake_word_model}
Hey, did you ever get it to work? I am having the same problem with my AtomS3 paired with the Echo base. Cannot even get the mic to work…
Trying to play sounds as a media device, results in this error in the esphome logs:
[18:16:50][E][speaker_media_player.pipeline:112]: Media reader encountered an error: ESP_ERR_NO_MEM
[18:16:50][E][speaker_media_player:326]: The announcement pipeline’s file reader encountered an error.
I would to know as well.
Difference, I have the more basic AtomS3 Lite, still with the Echo base.
Basically I’m trying the create a Voice assistant unit just like the ready-made ESPHome project with the older M5Stack Echo but with newer hardware that are the AtomS3 Lite and Echo base.
I tried something, but that did not work. (At least the device does work, it’s not crashing.)
I took the Atom Echo project yaml and mostly changed the GPIO pin number to what I thought were the equivalent ones on the AtomS3-Lite+EchoBase based on the image below:
In summary, related to GPIO pins, I changed:
  • i2s_audio
    – i2s_lrclk_pin: GPIO33 → GPIO8
    – i2s_bclk_pin: GPIO19 → GPIO6
  • microphone
    – i2s_din_pin: GPIO23 → GPIO7
  • speaker
    – i2s_dout_pin: GPIO22 → GPIO5
  • binary_sensor/echo_button
    – number: GPIO39 → GPIO41
  • light/led
    – pin: pin: GPIO27 → GPIO35
Well, the LED and the button do work. It’s the microphone and speaker that do not.
In the end, to make it work, is it simply a matter of correctly mapping the pins or is there something more fundamental that also need to be changed?
My config:
esphome:
  friendly_name: M5Stack AtomS3-Lite
esp32:
  board: esp32-s3-devkitc-1
  variant: esp32s3
  flash_size: 8MB
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: ""
ota:
  - platform: esphome
    password: ""
wifi:
  # ap:
  #   ssid: "M5Stack-Atoms3-Lite"
  #   password: ""
captive_portal:
esp32_ble_tracker:
  scan_parameters:
    active: true
bluetooth_proxy:
  active: true
# Voice Assistant part #
button:
  - platform: factory_reset
i2s_audio:
  - id: i2s_audio_bus
    i2s_lrclk_pin: GPIO8
    i2s_bclk_pin: GPIO6
microphone:
    i2s_din_pin: GPIO7
    adc_type: external
    pdm: true
    sample_rate: 16000
    correct_dc_offset: true
speaker:
    i2s_dout_pin: GPIO5
    dac_type: external
    bits_per_sample: 16bit
    sample_rate: 16000
    channel: stereo  # The Echo has poor playback audio quality when using mon audio
media_player:
  - platform: speaker
      format: WAV
    buffer_size: 6000
    volume_min: 0.4
    files:
    on_announcement:
      - if:
          condition:
            - microphone.is_capturing:
          then:
            - script.execute: stop_wake_word
      - light.turn_on:
          blue: 100%
          red: 0%
          green: 0%
          brightness: 100%
          effect: none
    on_idle:
      - script.execute: reset_led
voice_assistant:
  micro_wake_word:
  microphone:
    channels: 0
    gain_factor: 4
  auto_gain: 31dBFS
  on_listening:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Slow Pulse"
  on_stt_vad_end:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Fast Pulse"
  on_tts_start:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        brightness: 100%
        effect: none
  on_end:
    # Handle the "nevermind" case where there is no announcement
    - wait_until:
        condition:
          - media_player.is_announcing:
        timeout: 0.5s
    # Restart only mWW if enabled; streaming wake words automatically restart
    - if:
        condition:
          - lambda: return id(wake_word_engine_location).state == "On device";
        then:
          - wait_until:
              - and:
                  - not:
                      voice_assistant.is_running:
                  - not:
                      speaker.is_playing:
          - lambda: id(va).set_use_wake_word(false);
          - micro_wake_word.start:
  on_error:
    - light.turn_on:
        red: 100%
        green: 0%
        blue: 0%
        brightness: 100%
        effect: none
    - delay: 2s
    - delay: 2s  # Give the api server time to settle
  on_timer_finished:
    - wait_until:
        not:
    - switch.turn_on: timer_ringing
    - light.turn_on:
        red: 0%
        green: 100%
        blue: 0%
        brightness: 100%
    - wait_until:
        - switch.is_off: timer_ringing
    - light.turn_off: led
binary_sensor:
  # button does the following:
  # short click - stop a timer
  # if no timer then restart either microwakeword or voice assistant continuous
  - platform: gpio
    pin:
      number: GPIO41
      inverted: true
    disabled_by_default: true
    entity_category: diagnostic
    on_multi_click:
      - timing:
          - ON for at least 50ms
          - OFF for at least 50ms
        then:
          - if:
              condition:
                switch.is_on: timer_ringing
              then:
              else:
      - timing:
          - ON for at least 10s
        then:
          - button.press: factory_reset_btn
    device_class: occupancy
light:
  - platform: esp32_rmt_led_strip
    entity_category: config
    pin: GPIO35
    default_transition_length: 0s
    chipset: WS2812
    num_leds: 1
    rgb_order: grb
    effects:
      - pulse:
          transition_length: 250ms
          update_interval: 250ms
          min_brightness: 50%
          max_brightness: 100%
      - pulse:
          transition_length: 100ms
          update_interval: 100ms
          min_brightness: 50%
script:
  - id: reset_led
    then:
      - if:
          condition:
            - switch.is_on: use_listen_light
          then:
            - light.turn_on:
                red: 100%
                green: 89%
                blue: 71%
                brightness: 60%
                effect: none
          else:
            - if:
                condition:
                  - lambda: return id(wake_word_engine_location).state != "On device";
                then:
                  - light.turn_on:
                      red: 0%
                      green: 100%
                      blue: 100%
                      brightness: 60%
                      effect: none
                else:
    then:
      - if:
          condition:
            and:
              - not:
                  - voice_assistant.is_running:
          then:
      - if:
          condition:
            and:
              - not:
              - lambda: return id(wake_word_engine_location).state == "In Home Assistant";
          then:
            - lambda: id(va).set_use_wake_word(true);
  - id: stop_wake_word
    then:
      - if:
          condition:
          then:
      - if:
          condition:
          then:
            - micro_wake_word.stop:
switch:
    optimistic: true
    on_turn_on:
    on_turn_off:
    optimistic: true
    on_turn_off:
      # Turn off the repeat mode and disable the pause between playlist items
      - lambda: |-
                ->make_call()
                .perform();
      # Stop playing the alarm
          announcement: true
    on_turn_on:
      # Turn on the repeat mode and pause for 1000 ms between playlist items/repeats
      - lambda: |-
              ->make_call()
              .perform();
          announcement: true
      - delay: 15min
select:
    name: Wake word engine location
    optimistic: true
    restore_value: true
    options:
      - In Home Assistant
      - On device
    initial_option: On device
    on_value:
      - if:
          condition:
            lambda: return x == "In Home Assistant";
          then:
            - delay: 500ms
      - if:
          condition:
            lambda: return x == "On device";
          then:
            - delay: 500ms
micro_wake_word:
  vad:
  models:
    - model: okay_nabu
    - model: hey_mycroft
    - model: hey_jarvis
I can’t make it work either. As I mentioned in my first post the only way I can get the speaker to work is by first installing Atomic Echo Base XiaoZhi Voice Assistant then without unpluging the device from power I reflash it with the esphome config I posted and the speaker continue to work and is recognized by home assistant as a media device and can play any sound.
But if I unplug the power from the device and plug it back the speaker stops working and I cannot turn it on (but it’s still available in home assistant). I believe there is a command to enable/turn on the speaker that the XiaoZhi is using but I cannot figure out what that is.
Following in case you’ve had any success
Hi, I tested Atom echo + base on UIFlow 2.0 and it’s working at first tentative. I post the code, maybe it can help someone more skilled than me to unlock it on esphome
Based on the setup above I tested the following config:
i2c:
  sda: GPIO25
  scl: GPIO21
  scan: true
  frequency: 100kHz #higher values lead to bus scanning failure
audio_dac:
  - platform: es8311
    use_mclk: True
    sample_rate: 48000
    i2c_id: bus_a
    use_microphone: True
i2s_audio:
  - id: i2s_audio_bus
    i2s_lrclk_pin: GPIO19
    i2s_bclk_pin: GPIO33  # labelled sck on Echo Base
microphone:
    i2s_din_pin: GPIO22
    adc_type: external
    pdm: true
    sample_rate: 16000
speaker:
    i2s_dout_pin: GPIO23
    dac_type: external
    sample_rate: 16000
    channel: stereo
Logs are clean but it’s not working yet, although it’s making noises.
Any hint would be appreciated, thanks in advance.
Have you tried this config with the GPIO pin configuration from earlier in the thread? I’ve got something very similiar - but like you still not working. I was able to write a quick .cpp program - I know that mic / speaker is working on the echo - I had to import the M5EchoBase.h file to configure the EchoBase - I wasn’t able to get this working without that in the *.cpp / PlatformIO demo project I built.
I was trying to figure out if I could add a new hardware config to ESPHome for this combo - but I couldn’t even figure out where to start on github - so if anyone has pointers I am happy to try to take that on.
I’ve got the speaker working – here is my config. I took the M3CoreS3 repo and modified it for the ATOM.
#esphome:
##  name: m5atom-echo
##  friendly_name: M5Atom Echo
##  platform: ESP32
##  board: m5stack-atom
substitutions:
  friendly_name: Test Device
esphome:
  name_add_mac_suffix: true
  friendly_name: ${friendly_name}
  min_version: 2025.5.0
  platformio_options:
    board_build.f_cpu : 240000000L
  libraries:
    - m5stack/M5Unified@^0.2.3
  on_boot:
    priority: -100
    then:
      - delay: 2s
esp32:
  variant: esp32s3
  flash_size: 8MB
  framework:
    type: esp-idf
logger:
 level: VERY_VERBOSE
api:
  encryption:
    key: "**********"
ota:
  - platform: esphome
    password: "****************"
wifi:
  manual_ip:
    static_ip: 0.0.0.0
    gateway: 0.0.0.0
    subnet: 0.0.0.0
    dns1: 0.0.0.0
    dns2: 8.8.8.8
  ap:
    ssid: "Test-Device Hotspot"
    password: "*********"
captive_portal:
  - source:
      type: git
      url: https://github.com/mrpullen/M5AtomS3-EchoBase-Esphome
    refresh: 0s
globals:
  - id: speaker_volume
    type: int
    restore_value: no
    initial_value: '5'
# Audio
board_m5atoms3:
m5atoms3_audio:
  i2s_bclk_pin: 6
  i2s_lrclk_pin: 8
microphone:
  - platform: m5atoms3_audio
    m5atoms3_audio_id: m5atoms3_audio_1
    adc_type: external
    i2s_din_pin: 7
    pdm: false
speaker:
    dac_type: external
    i2s_dout_pin: 5
    mode: mono
    num_channels: "1"
    sample_rate: "16000"
media_player:
  - platform: speaker
    codec_support_enabled: true
    buffer_size: 12000
    volume_min: 0.4
      speaker: m5atoms3_spk
      format: MP3
  - platform: speaker
    buffer_size: 12000
    volume_min: 0.4
      format: WAV
binary_sensor:
  - platform: gpio
    pin: GPIO41
    name: "Play Tone Button"
    on_press:
      then:
        - script.execute: play_tone_script
script:
  - id: play_tone_script
    mode: restart
    then:
      - media_player.play_media:
          media_url: "https://github.com/m5stack/M5CoreS3-Esphome/raw/refs/heads/main/sounds/wav/click_1.wav"
After deploying this when I press the screeen I hear the click sound - so now it’s just sorting out how to get the actual media player and speaker to work as expected. I have a self hosted CA - and my home assistant has a cert issued from there -so having issues playing media directly… anyone know how to solve that I can test this end to end.
Latest configuration here - is working I can hear the voice and radio - it’s still a bit choppy need to work a bit more on how the buffering is working.
substitutions:
esphome:
  platformio_options:
  libraries:
  on_boot:
    priority: -100
    then:
      - delay: 2s
esp32:
  variant: esp32s3
  flash_size: 8MB
  framework:
    type: esp-idf
##    type: arduino  # Required for HTTPS and I2S audio
logger:
 level: VERY_VERBOSE
api:
  encryption:
    key: "*********"
ota:
  - platform: esphome
    password: "*******"
wifi:
  manual_ip:
    static_ip: 0.0.0.0
    gateway: 0.0.0.0
    subnet: 255.255.255.0
    dns1: 0.0.0.0
    dns2: 8.8.8.8
  ap:
    password: "**************"
captive_portal:
  - source:
      type: git
      ref: main
    refresh: 0s
globals:
    type: int
    restore_value: no
    initial_value: '128'
# Audio
board_m5atoms3:
m5atoms3_audio:
speaker:
    buffer_size: 1024
    buffer_count: 16
    num_channels: "1"
    sample_rate: "48000"
media_player:
  - platform: speaker
    buffer_size: 16384
    volume_min: 0.4
      format: WAV
      sample_rate: 48000
      num_channels: "1"
binary_sensor:
  - platform: gpio
    pin: GPIO41
    on_press:
      then:
script:
    mode: restart
    then:
I will post again once I get the issue with the audio choppiness sorted out - then again when I get the mic and voice assistant working.
What I got so far is similar but still cannot make the sound clear I get only a static noise when playing any media.
substitutions:
  micro_wake_word_model: okay_nabu # alexa, hey_jarvis, hey_mycroft are also supported
esphome:
  platformio_options:
    build_flags:
      # - "-w" # https://docs.platformio.org/en/lai2cdev/projectconf/sections/env/options/build/build_flags.html
      -DESP32S3
      -DBOARD_HAS_PSRAM
      -mfix-esp32-psram-cache-issue
      -DCORE_DEBUG_LEVEL=5
      -DARDUINO_USB_CDC_ON_BOOT=1
      -DARDUINO_USB_MODE=1
  on_boot:
    then:
        - logger.log: "Init echo base. id(i2cdev)"
            ESP_LOGI("startup", "Initializing I/O expander to power on ES8311...");
            id(i2cdev).write_byte(0x07, 0x00);  // Set direction to output
            id(i2cdev).write_byte(0x0D, 0xFF);  // Set pull-up if needed
            id(i2cdev).write_byte(0x03, 0x6E);  // Invert logic (if needed)
            id(i2cdev).write_byte(0x05, 0xFF);  // Output HIGH (enable power)
esp32:
  variant: esp32s3
  flash_size: 8MB
  framework:
    type: esp-idf
psram:
  mode: octal
  speed: 80MHz
wifi:
  networks:
    - ssid: !secret ssid
      password: !secret pass
  id:
    wifi_id
  ap:
# Enable logging
logger:
api:
  # encryption:
  #   key: "*****"
ota:
  - platform: esphome
    password: "******"
captive_portal:
improv_serial:
i2c:
  - id: bus_a
    sda: GPIO45
    scl: GPIO0
    scan: true
  - id: bus_b
    sda: GPIO38
    scl: GPIO39
    scan: true
i2c_device:
   i2c_id: bus_b
   address: 0x43
audio_dac:
  - platform: es8311
    sample_rate: 48000
    use_mclk: false
    i2c_id: bus_b
i2s_audio:
  - id: i2s_output
    i2s_bclk_pin: GPIO8
speaker:
    i2s_audio_id: i2s_output
    i2s_dout_pin: GPIO7
    dac_type: external
    sample_rate: 24000
    channel: left
    use_apll: true
    mclk_multiple: 384
microphone:
    i2s_din_pin: GPIO5
    adc_type: external
    pdm: true
    sample_rate: 24000
media_player:
  - platform: speaker
      format: WAV
    buffer_size: 6000
    files:
I am using a device AtomS3r + Atomic echo base.
I present the code on which the sound works smoothly… now other peripherals…
esphome:
  friendly_name: Z_AtomEcho
  platformio_options:
  libraries:
  on_boot:
    priority: -100
    then:
      - delay: 2s
esp32:
  board: esp32-s3-devkitc1-n8r8 #esp32-s3-devkitc-1
  variant: esp32s3
  flash_size: 8MB
  framework:
    type: esp-idf
psram:
  mode: octal
  speed: 80MHz
# Enable logging
logger:
  level: DEBUG
  logs:
    sensor: WARN  # avoids logging debug sensor updates
api:
ota:
wifi:
captive_portal:
  - source:
      type: git
      ref: main
    refresh: 0s
globals:
    type: int
    restore_value: no
# Audio
board_m5atoms3:
m5atoms3_audio:
#___________________________________________________
i2c:
  # Magistrala 1: Audio/Dotyk (G38/G39) - Używana przez ES8311 (0x18) i Dotyk (0x43)
  - sda: GPIO38
    scl: GPIO39
    frequency: 400kHz
    scan: True
i2s_audio:
  i2s_bclk_pin: GPIO8
speaker:
    i2s_dout_pin: GPIO5 # wcześniej probowałem 5
    dac_type: external
    sample_rate: 48000
    channel: mono
    buffer_duration: 200ms
media_player:
  - platform: speaker
    buffer_size: 16384
    volume_min: 0.0
    volume_max: 0.5
      format: WAV
      speaker: i2s_speaker
      sample_rate: 48000
      num_channels: "1"
I still get only static sound when playing any media. I didn’t change anything just copy pasted your config.
Hello!
Hi. After further testing, I also encountered the typical issues. No sound after a power loss. The only stable solution is to add two speakers and two media players. The Atom player doesn’t work, but the i2s player does. It has a problem with decoding – MP3s are fine, but the music assistant sound is bad. Most importantly, the speaker reinitializes after a power loss. Everything stops working when I expand the code to include display options. The speaker is dead again after a power loss. I tested on EspHome 2025.9. I think the C++ configuration is not well-developed for AtomS3R + Atomic Echo base. “mrpullen,” will there be an update?
esphome:
  platformio_options:
  libraries:
  on_boot:
    priority: -100
    then:
      - delay: 2s
esp32:
  variant: esp32s3
  flash_size: 8MB
  framework:
    type: esp-idf
    sdkconfig_options:
        CONFIG_SPIRAM_RODATA: "y"
        CONFIG_SPIRAM_FETCH_INSTRUCTIONS: "y"
        CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC: "y"
psram:
  mode: octal
  speed: 80MHz
# Enable logging
logger:
  level: DEBUG
  logs:
api:
  encryption:
    key: x
ota:
  - platform: esphome
    password: x
wifi:
  ssid: x
  password: x
  ap:
    ssid: x
    password: x
captive_portal:
globals:
    type: int
    restore_value: no
# ______________________ Board ______________________
  - source:
      type: git
      ref: main
    refresh: 0s
# Audio BOARD
board_m5atoms3:
m5atoms3_audio:
# ______________________ I2C ______________________
i2c:
  - sda: GPIO38
    scl: GPIO39
    frequency: 400kHz
    scan: False
# ______________________ I2S ______________________
i2s_audio:
  i2s_bclk_pin: GPIO8
# ______________________ SPEAKER ______________________
speaker:
    buffer_size: 1024 #1024
    buffer_count: 16 #16
    num_channels: "1"
    sample_rate: "48000"  #48000
    i2s_dout_pin: GPIO5
    dac_type: external
    sample_rate: 48000
    channel: mono
# ______________________ MICROPHONE (Mikrofon) ______________________
microphone:
    i2s_audio_id: i2s_audio_bus
    adc_type: external
    sample_rate: 16000
    channel: stereo
    i2s_din_pin: GPIO7
# ______________________ MEDIA PLAYER ______________________
media_player:
  - platform: speaker
    buffer_size: 16384
    volume_min: 0.0
    volume_max: 0.5
      format: WAV
      sample_rate: 48000
      num_channels: "1"
  - platform: speaker
    buffer_size: 16384
    volume_min: 0.0
    volume_max: 0.5
      format: WAV
      sample_rate: 48000
      num_channels: "1"
# ______________________ SCRIPT  ______________________
script:
    mode: restart
    then:
          media_url: |-
          announcement: False
binary_sensor:
  - platform: gpio
    pin: GPIO41
    on_press:
      then:
Going to give this a try - I kept hacking away at the bits to make the sound better but if you are getting decent sound with this config. I essentially never improved anything with all my dev branches and had moved on to working on the HuggingFace SO101 Robot arms.
I will see about resolving the power issues - I honestly hadn’t tested that and not sure why that would be happening - but will take a look.
Has anyone had success in enabling the ES8311? The issue is that it requires some additional initialization and I suspect the amplifier should be turned on through the io expander. But so far Inhad no luck turning it on. Based on the schematic it is pull up pin, so itnis on by default. Tbh I am clueless at the moment.
I finally could understand a bit what was going on. So based on mrpullen fork M3CoreS3 repo, I forked into a new one specific for the AtomS3R as per defined my settings in yaml to use this new repository. Additionally, I noticed also the issue you mentioned about getting the sound mute after enabling the display and noticed it was caused due to a specific call on the display code that would restart the whole board when initializing the display, causing the conflict in the paramaters set on the initialization of the audio. Therefore, I simply changed the below code to start the display setup only in the context of the display ‘m5atoms3_display.cpp’:
old code:
void M5AtomS3Display::setup() {
ESP_LOGI(TAG, “setup”);
M5.begin();
_canvas = new LGFX_Sprite(&M5.Display);
_canvas->setPsram(true);
_canvas->createSprite(M5.Display.width(), M5.Display.height());
new code:
M5.Display.begin();
By changing this, the display initializes without creating issues on audio initialization.
This is my full yaml configuration:
esphome:
  platformio_options:
  libraries:
  on_boot:
    - priority: -100
      then:
        - delay: 2s
esp32:
  variant: esp32s3
  flash_size: 8MB
  framework:
    type: esp-idf
    sdkconfig_options:
psram:
  mode: octal
  speed: 80MHz
logger:
  level: DEBUG
  logs:
    sensor: WARN
api:
  encryption:
    key: ***
ota:
  - platform: esphome
    password: ***
wifi:
  ap:
    ssid: **
    password: **
captive_portal:
globals:
    type: int
    restore_value: no
  - source:
      type: git
      url: https://github.com/krcarneiro/M5AtomS3-EchoBase-Esphome
      ref: main
    refresh: 0s
board_m5atoms3r:
m5atoms3_audio:
i2c:
  - sda: GPIO38
    scl: GPIO39
    frequency: 400kHz
    scan: False
i2s_audio:
  i2s_bclk_pin: GPIO8
speaker:
    num_channels: "1"
    i2s_dout_pin: GPIO5
    dac_type: external
    sample_rate: 48000
    channel: mono
microphone:
    adc_type: external
    sample_rate: 16000
    channel: stereo
    i2s_din_pin: GPIO7
media_player:
  - platform: speaker
    task_stack_in_psram: True
    buffer_size: 16384
    volume_min: 0.0
    volume_max: 0.5
      format: WAV
      sample_rate: 48000
      num_channels: "1"
script:
    mode: restart
    then:
          media_url: |-
          announcement: False
binary_sensor:
  - platform: gpio
    pin: GPIO41
    on_press:
      then:
spi:
  clk_pin: GPIO15
  mosi_pin: GPIO21
color:
  - id: my_red
    red: 100%
    green: 0%
    blue: 0%
  - id: my_yellow
    red: 100%
    green: 100%
    blue: 0%
  - id: my_green
    red: 0%
    green: 100%
    blue: 0%
  - id: my_blue
    red: 0%
    green: 0%
    blue: 100%
  - id: my_gray
    red: 50%
    green: 50%
    blue: 50%
font:
time:
display:
  - platform: m5atoms3_display
    model: st7789v
    dc_pin: GPIO42
    update_interval: 1s
    rotation: 270
    lambda: |-
      it.rectangle(0,  0, it.get_width(), it.get_height(), id(my_yellow));
      it.strftime((128 / 2), (128 / 3) * 1 + 5, id(roboto_24), id(my_red), TextAlign::CENTER, "%Y-%m-%d", id(esptime).now());
      it.strftime((128 / 2), (128 / 3) * 2 + 5, id(roboto_24), id(my_green), TextAlign::CENTER, "%H:%M:%S", id(esptime).now());
I am still dealing with the voice assistant stuff and I will bring the whole setup with voice assistant and other hardware as soon as I can .
In regards to the question raised by mr. Lajos, I noticed in this context is not necessary to enable ES8311, since this is already started by the board initialization. However, if you still want to deal with the I/O expander, I suggest you read PI4IOE5V6408 8-Bit I2C I/O Expander - ESPHome - Smart Home Made Simple, since this is a new component implemented by ESPhome, but completelly unecessary for now.
I think there were some differences with the code in esp_codec_dev compared to the ES8311 clock configuration
The register 0x02 maybe incorrectly configured when MCLK is not used.
Try this component:
  - source: github://m5stack/esphome-yaml/components@main
    components: es8311
    refresh: 1d
And audio configuration:
# I2C Bus Configuration
i2c:
  - id: bsp_bus
    sda: GPIO45
    scl: GPIO0
  - id: ext_bus # used on atomic echo base
    sda: GPIO38
    scl: GPIO39
# Ehco Base GPIO Expander
pi4ioe5v6408:
  - id: pi4ioe5v6408_hub
    i2c_id: ext_bus
    address: 0x43
# I2S Bus Configuration
i2s_audio:
  - id: i2s_audio_bus
    i2s_bclk_pin: GPIO8
    # i2s_mclk_pin is not used
audio_dac:
  - platform: es8311
    i2c_id: ext_bus
    sample_rate: 48000
    use_microphone: false  # analog microphone here
    use_mclk: false        # no mclk pin is connected
microphone:
    sample_rate: 16000
    i2s_din_pin: GPIO7
    adc_type: external
speaker:
    i2s_dout_pin: GPIO5
    dac_type: external
    sample_rate: 48000
    channel: left
media_player:
  - platform: speaker
    name: "Echo Base Speaker"
    volume_min: 0.5
    volume_max: 0.8
      format: FLAC
      sample_rate: 48000
      num_channels: 1
    files:
      - id: clicked
        file: https://github.com/esphome/home-assistant-voice-pe/raw/dev/sounds/wake_word_triggered.flac
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO41
      mode: INPUT_PULLUP
      inverted: true
    internal: true
    on_click:
      - script.execute:
          priority: true
          sound_file: !lambda return id(clicked);
switch:
  # NS4150B
  - platform: gpio
    pin:
      pi4ioe5v6408: pi4ioe5v6408_hub
      number: 0
      mode:
        output: true
script:
  - id: play_sound
    parameters:
      priority: bool
      sound_file: "audio::AudioFile*"
    then:
      - lambda: |-
          if (priority) {
            id(echo_base_speaker)
              ->make_call()
              .set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_STOP)
              .perform();
          if ( (id(echo_base_speaker).state != media_player::MediaPlayerState::MEDIA_PLAYER_STATE_ANNOUNCING ) || priority) {
              ->play_file(sound_file, true, false);
Does anyone have the microphone working?
Speaker works with external_components, but mic is still silent.
audio_dac:
- platform: es8311
  i2c_id: ext_i2c
  sample_rate: 48000
  use_mclk: false
microphone:
- id: microphone_id
  platform: i2s_audio
  adc_type: external
  i2s_din_pin: GPIO07
  sample_rate: 16000
  use_apll: true
- platform: sound_level
  microphone: microphone_id
  passive: true
  peak: { name: 'Peak Loudness'    }
  rms:  { name: 'Average Loudness' }
button:
- name: 'capture start'
  platform: template
  on_press: [ microphone.capture ]
- name: 'capture stop'
  platform: template
  on_press: [ microphone.stop_capture ]
binary_sensor:
- name: 'Capturing'
  platform: template
  condition: { microphone.is_capturing }
