How to turn on the smart socket when restoring power
I have a question about the Aubess smart switch.
When power is lost/restored to the switch, I would like it not to restore the previous state, but to switch to the “on” state.
I tried the “Power-on behavior” property, for some reason only the value ‘off’ works, but ‘on’ does not.
Will there be any tips? Or maybe write some kind of automation so that when power is restored, it turns on the outlet.
If possible, can you throw off the sample code?
PS: I use a smart switch to turn on the light. When switching to the manual switch, you need the light to turn on, and it restores the past state of “off” and the light does not light up
It is problem related to poor implementation of switch firmware. This works on most smart switches (i.e. my Xiaomi Mi power plug ZigBee EU ZNCZ04LM)
Just use an automation triggered by state from Unavailable.
Can you tell me in more detail? I’m just a beginner, I want to figure it out
Automations are under settings, go have a play.
Read the docs as always especially the ones about automations.
An automation has a trigger, a condition if you want one and an action.
What you need is trigger - state from Unavailable and action - call service - turn switch on - select your switch.
It really is very easy, but you won’t learn if you don’t have a try.
And please read the docs that’s what they are there for.
I wrote this code. But this code doesn’t work for some reason.
This code is triggered only 1 time when restarting Home Assistance
What is my mistake?
# Loads default set of integrations. Do not remove. TEST
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
binary_sensor:
    sensors:
      power_loss:
        friendly_name: "Power loss"
        device_class: power
        value_template: "{{ is_state('switch.0xa4c138c4856a9f2a', 'unavailable') }}"
automation:
  - alias: "Turn on the smart socket after power is restored"
      - platform: state
        entity_id: binary_sensor.power_loss
        to: 'off'
      - service: switch.turn_on
        entity_id: switch.0xa4c138c4856a9f2a
script: !include scripts.yaml
scene: !include scenes.yaml
Tested it.
My code works, but not always. I need to bring my code to mind
Try something like this, you don’t need a binary sensor that is just complicating things. And this can be easily created in the gui.
description: "any name you want"
mode: single
  - platform: state
    entity_id:
      - your switch
condition: []
    data: {}
      entity_id: your switch
I figured out the problem of the switch.
The ‘Power-on behavior’ status switches to the ‘on’ state only if the power supply to the device has not been on for more than 5 seconds. Otherwise it won’t work.
It turns out that the script is not needed here.
Thank you all
