I’d like to add something since I’m not seeing it anywhere else. Doing this doesn’t require any custom cards. Just vanilla HA, HA helpers, HA automations and official wled integration.
You can use the state of an input select helper or input select integration (in config.yaml) then add helper to a card in lovelace to easily change the effect. Helpers can be used via automations on all wled attribute states that are available with service calls. Also input select helper state can be set from wled attribute state when effect is changed by some other means such as changing a preset or changing the effect in wled web ui. Again this can be done for all wled attributes exposed in home assistant.
Here are my automations for controlling wled. I made a separate one for each but I’m sure this could be done more elegantly.
alias: Set Effect
description: ''
- platform: state
entity_id: input_select.effect
condition: []
- service: wled.effect
effect: '{{ states("input_select.effect") }}'
entity_id: light.wled
mode: single
alias: Set effect to dropdown
description: ''
- platform: state
attribute: effect
condition: []
- service: input_select.select_option
option: '{{ state_attr("light.wled", "effect") }}'
mode: single
alias: Set Intensity
description: ''
- platform: state
entity_id: input_number.intensity
for: '00:00:00'
condition: []
intensity: '{{ states("input_number.intensity") }}'
mode: single
max: 10
alias: Set intensity to slider
description: ''
- platform: state
attribute: intensity
condition: []
- service: input_number.set_value
value: '{{ state_attr("light.wled", "intensity") }}'
mode: single
alias: Set palette
description: ''
- platform: state
entity_id: input_select.palette_list
for: '00:00:00'
condition: []
palette: '{{ states("input_select.palette_list") }}'
mode: single
alias: Set palette to dropdown
description: ''
- platform: state
attribute: palette
condition: []
option: '{{ state_attr("light.wled", "palette") }}'
mode: single
alias: Set Preset
description: ''
- platform: state
entity_id: input_select.preset
for: '00:00:00'
condition: []
- service: wled.preset
preset: '{{ states("input_select.preset") }}'
mode: single
alias: Set preset to dropdown
description: ''
- platform: state
attribute: preset
condition: []
option: '{{ state_attr("light.wled", "preset") }}'
mode: single
alias: Set Reverse
description: ''
- platform: state
entity_id: input_boolean.reverse
for: '00:00:00'
condition: []
reverse: '{{ states("input_boolean.reverse") }}'
mode: single
alias: Set Speed
description: ''
- platform: state
entity_id: input_number.speed
for: '00:00:00'
condition: []
speed: '{{ states("input_number.speed") }}'
mode: single
alias: Set speed to slider
description: ''
- platform: state
attribute: speed
condition: []
value: '{{ state_attr("light.wled", "speed") }}'
mode: single
alias: Set Brightness
description: ''
- platform: state
entity_id: input_number.brightness
condition: []
- service: light.turn_on
brightness: '{{ states("input_number.brightness") }}'
mode: single
alias: Set brightness to slider
description: ''
- platform: state
condition: []
value: '{{ state_attr("light.wled", "brightness") }}'
mode: single
