How to uninstall hangouts
I previously used Hangouts for notifications. I started noticing I was missing some notifications and checked the logs a crazy amount of log spam from hangups/client.py
I ended up switching to Signal for notifications, and disabling all of my hangouts notifications, but I still have an insane amount of logspam from this client. Here are some of the logs
2020-07-30 04:13:52 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.8/site-packages/hangups/client.py", line 138, in connect
    await self._listen_future
  File "/usr/local/lib/python3.8/site-packages/hangups/channel.py", line 197, in listen
    await self._longpoll_request()
  File "/usr/local/lib/python3.8/site-packages/hangups/channel.py", line 298, in _longpoll_request
    await self._on_push_data(chunk)
  File "/usr/local/lib/python3.8/site-packages/hangups/channel.py", line 332, in _on_push_data
    await self.on_receive_array.fire(data_array)
  File "/usr/local/lib/python3.8/site-packages/hangups/event.py", line 59, in fire
    await gen
  File "/usr/local/lib/python3.8/site-packages/hangups/client.py", line 347, in _on_receive_array
    wrapper = json.loads(array[0]['p'])
and
2020-07-30 03:30:51 ERROR (MainThread) [homeassistant.util.logging] Exception in async_handle_update_users_and_conversations when dispatching 'hangouts_connected': ()
  File "/usr/src/homeassistant/homeassistant/components/hangouts/hangouts_bot.py", line 341, in async_handle_update_users_and_conversations
    await self._async_list_conversations()
  File "/usr/src/homeassistant/homeassistant/components/hangouts/hangouts_bot.py", line 310, in _async_list_conversations
    ) = await hangups.build_user_conversation_list(self._client)
  File "/usr/local/lib/python3.8/site-packages/hangups/conversation.py", line 30, in build_user_conversation_list
    conv_states, sync_timestamp = await _sync_all_conversations(client)
  File "/usr/local/lib/python3.8/site-packages/hangups/conversation.py", line 110, in _sync_all_conversations
    response = await client.sync_recent_conversations(request)
  File "/usr/local/lib/python3.8/site-packages/hangups/client.py", line 672, in sync_recent_conversations
    await self._pb_request('conversations/syncrecentconversations',
  File "/usr/local/lib/python3.8/site-packages/hangups/client.py", line 433, in _pb_request
    raise exceptions.NetworkError(
hangups.exceptions.NetworkError: Request failed with status 0: 'User over quota.
These errors repeat over and over for minutes or hours at a time making attempting to find anything else in the logs next to impossible. Has anyone been able to completely remove hangouts?
I saw in another thread someone mentioned there might be something in the .storage dir, but I don’t see anything there that looks like Hangouts.
➜  config ls ./.storage
auth                                                 core.config_entries                                  frontend.user_data_1b34be8e583a469bb7e8a7922c42c264  hacs.installed                                       http                                                 person
auth_module.totp                                     core.device_registry                                 google_assistant                                     hacs.removed                                         lovelace                                             smartthings
auth_provider.homeassistant                          core.entity_registry                                 hacs                                                 hacs.repositories                                    lovelace_resources                                   wyzesense.json
cloud                                                core.restore_state                                   hacs.critical                                        hassio                                               mobile_app                                           zha.storage
core.area_registry                                   core.uuid                                            hacs.hacs                                            homekit_controller-entity-map                        onboarding
Aaaaaand I’ve spent too much time digging through files and configs while ignoring the obvious place in the UI. In case anyone else is looking for this, just go to integrations, click the 3 dots on hangouts and then delete
