How to uninstall Wiz integration
I have a mostly functional Wiz integration. However, when bulbs are moved around, occasionally I get into a condition where some will get lost and won’t sync from Wiz to HA (I’ve verified each device’s MAC address). The only way I’ve found to fix this in the past was to completely remove Wiz integration and add it, allowing everything to completely sync again. However, I can’t remember or find again how to accomplish this given the new UI-only integration method. Would someone mind assisting? Is there a folder I need to remove?
Go to the integrations overview and select the Wiz integration. Then click on the 3 dots and select Delete
(screenshot is from another integration since I don’t use Wiz)
Unless I’m missing it, Wiz doesn’t have this option.
In this case, I think you would need to delete all Integration entries. Then the integration itself should also be removed from your integrations overview and can be added again.
At least I dont know any other option.
That worked. Thank you!
