IDK if it’s even possible to bring that setup to the current release, OTOH I have seen that you can select a specific version when updating but no idea if this can be done from the release you are running.
If you haven’t done much to customize your setup; I would follow the advice of my fellow HA user to start from scratch with the latest release.
Thanks for chiming in, yea I kinda figured a new install was in order. I do have two devices that from that timeframe that I’d like to retain. I’d assume the process to find and add devices has improved. I do recall it took me a while to get them going last time.
HA has really changed A LOT since then and if you want to make sure that your devices work (which they wil most likely do), have a look at the official HA integrations page or do a search on the forum to see if they are mentioned.
