There is an update according to deCONZ, but when I click it nothing seems to happen. GCFFlasher_internal, was referenced somewhere for a manual update, but the command does not exist in rasberry pi.
I run deCONZ in a docker.
You need to follow the instructions from the docker GitHub. You will need to run scripts over ssh in the container
So, I have the same problem deconz says there is a new firmware version but the web UI doesn’t install it.
The instructions I have found, unless I am on the wrong track, want me to make changes to hassio so I can ssh as a developer into a lower level than standard ssh allows. This emphasises that it is not for end users. Am I in the wrong place? Is there a simpler way.
I’m running deconz inside HA as an add-on.
I want the firmware update to hopefully stop my xiaomi switches disappearing after an hour or two.
Did you fix? Im having same problem
My solution was to install deconz on my pc and plug in the usb device. It promptly upgraded it. Popped it back into pi and all done.
