How to update debug environment
I’m currently debugging on windows with visual studio code and docker. I just did a ‘git pull’ to the the current dev version of Home Assistant core. When I now want to start debugging I get the following error:
Exception has occurred: ModuleNotFoundError       (note: full exception trace is shown but execution is paused at: _run_module_as_main)
No module named 'aiohttp_asyncmdnsresolver'
  File "/workspaces/core/homeassistant/helpers/aiohttp_client.py", line 18, in <module>
    from aiohttp_asyncmdnsresolver.api import AsyncMDNSResolver
  File "/workspaces/core/homeassistant/helpers/config_entry_oauth2_flow.py", line 33, in <module>
    from .aiohttp_client import async_get_clientsession
  File "/workspaces/core/homeassistant/components/auth/__init__.py", line 158, in <module>
    from homeassistant.helpers.config_entry_oauth2_flow import OAuth2AuthorizeCallbackView
  File "/workspaces/core/homeassistant/bootstrap.py", line 41, in <module>
    from .components import (
  File "/workspaces/core/homeassistant/runner.py", line 16, in <module>
    from . import bootstrap
  File "/workspaces/core/homeassistant/__main__.py", line 192, in main
    from . import config, runner
  File "/workspaces/core/homeassistant/__main__.py", line 227, in <module>
    sys.exit(main())
  File "/usr/local/lib/python3.12/runpy.py", line 88, in _run_code
    exec(code, run_globals)
  File "/usr/local/lib/python3.12/runpy.py", line 198, in _run_module_as_main (Current frame)
    return _run_code(code, main_globals, None,
ModuleNotFoundError: No module named 'aiohttp_asyncmdnsresolver'
So my guess is, that the dependencies are not correctly updated. Is there any documentation how to correctly update the dev environment?
Running into the same problem again. Last time it was fixed after multiple restarts. Now that doesn’t work
