How to update HA incrementally
I currently have Home assistant Core 2024.8 installed.
I am thinking of updating it, however in the update section it shows me that i can update to version 2025.4.4
This is a way too big of a jump and i would like to take it easy one step at a time.
So i first want to update to 2024.9.x, then to 2024.10.x and so on until i reach current version.
Is there any way to achieve this?
See updating HA using the CLI (about 1/3 down the page)
The command line is HA core update and yih van target a specific version.
Thats said you’re probably ok to skip 2-3 at a time. Just read the release notes and understand the issues for each release. Just make sure you take a backup first so yih can easily rollback.
Thank you, i did read the docs, but i stopped at “Updating home assistant core” where it only showed CLI command “ha core update --backup” so i thought that was it.
But now that you mention, it must be there, and then i actually scrolled down even further and there was a section " RUNNING A SPECIFIC VERSION" which shows how to perform update to specific version.
I would have found this info if it were next to primary update info.
thank you
Hi, if @NathanCu his answer has helped you, please take the time to mark the solution as the answer, you do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
Another option is to start by making a full unencrypted backup and copy the tar file to a thumb drive. Then just install the latest version and restore.
