im trying to update hassio to 58.1 from 57.2, but when i click the update button it just goes round in circles and does nothing… ive waited ages and refreshed the page, but nothing happens…
Any ideas?
Gershy13
Any ideas?
Gershy13
You’re not the only one! The only way I’ve found to upgrade is to first install Samba, create a backup and then browse to \\hassio\backup and copy the backup file to your computer. Once you have a copy you can then reflash hassio and let it reinstall updates automatically. You’ll then log into your system at http://hassio.local:8123, reinstall Samba, copy your backup file and then restore your system. It should reboot and you should be up and running again.
Check your supervisor logs for errors while it’s attempting to upgrade http://hassio.local:8123/hassio/supervisor
. You may also want to check how much disk space you have free. You can SSH to resinos by following instructions at https://home-assistant.io/developers/hassio/debugging/ then run df -h
