I have set up an alarm system based on Homematic stuff. Motion sensors, window and door sensors etc. I can read and display the status in Lovelace like this:
(this is german, so Unscharf = unarmed, Hüllschutz = hull protect, Vollschutz = complete protection)
sensors:
alarm_status:
friendly_name: "Status Alarm"
value_template: >-
{%- if state_attr('homematic.ccu3', 'Status_Alarm_Aktiv_Var') == 0 -%}
Unscharf
{%- elif state_attr('homematic.ccu3', 'Status_Alarm_Aktiv_Var') == 1 -%}
Huellschutz
{%- elif state_attr('homematic.ccu3', 'Status_Alarm_Aktiv_Var') == 2 -%}
Vollschutz
{%- else -%}
Fehler
{%- endif -%}
As you see, I control the alarm system status by using switches in Lovelace:
switch:
switches:
alarm_unscharf_switch:
friendly_name: 'Alarm Unscharf'
turn_on:
service: homematic.set_variable_value
entity_id: homematic.ccu3
value: "0"
turn_off:
value: "0"
alarm_huellschutz_switch:
friendly_name: 'Alarm Hüllschutz'
turn_on:
value: "1"
turn_off:
value: "0"
alarm_vollschutz_switch:
friendly_name: 'Alarm Vollschutz'
turn_on:
value: "2"
turn_off:
value: "0"
As you also see in the screenshot, the Homematic status can change to “unarmed”, but the color of the switch still indicates to be active (on).
Question: how to toggle the switch back based on a sensor status?
