mfx
(mfx)
March 22, 2022, 6:48pm
1
Hey!
New version out … and the GUI doesn‘t give me any option. No supervisor (so confusing!). All tutorials say „go to supervisor“ or app-store! There is none! This is probably the 1000th thread like this. Because this is super confusing! Why did you choose this design? I even can‘t remember how my HA is called …is it core? Too many options / naming conventions.
Could somebody maybe help me find the right guide to have a supervisor? I‘m running a RPi with HA running not in docker and not as OS from you (because I want my own OS). Is it still not possible to use supervisor // have the full HA experience?
Kind regards
Pete
finity
March 22, 2022, 6:52pm
2
you can still have the “full HA experience”. But you just don’t have the supervisor.
It sounds like you have installed the HA Core installation in a python virtual environment?
if so then you need to update your HA via the command line in the venv you created when you installed HA.
mfx
(mfx)
March 22, 2022, 6:55pm
3
Yes! Python venv…! Is there a guide for updating? Can‘t find anything…
Tbh doesn‘t feel like a good experience when no tutorial can be followed Settings are so empty - and kinda useless imho - I hope in 2022 version this is better
mfx
(mfx)
March 22, 2022, 7:02pm
4
Here are the steps to update HA in a venv (old but I think they are still valid):
$ sudo systemctl stop [email protected]
$ sudo su -s /bin/bash homeassistant
$ source /srv/homeassistant/bin/activate
$ pip3 install --upgrade homeassistant
$ exit
$ sudo systemctl start [email protected]
If necessary change the user “homeassistant” in the second line to whatever user you used to install HA.
ah got it! thx @finity from another time
Just for information regarding the installation methods available.
And why do you want your own OS and make it yourself so difficult with such a critical system that manages your home?
Your distro’s python version may fall behind the minimum supported for Home Assistant Core
Home Assistant generally only supports the current stable version of python and one minor version behind. For example if the current python version is 3.8.5, the oldest python version supported is the 3.7.X branch of python. However, your operating system’s distribution of python may not stay current enough and you may find that your current python version has been deprecated and soon may no longer be…
mfx
(mfx)
March 22, 2022, 7:07pm
6
Hmm, I dislike the trend for every project to have its own OS. If you want to run more than one project with its own OS you have to decide … right? So I decided to ditch that and rather run them on my own… makes life easier in most cases — just not in this.
123
(Taras)
7
mfx:
Yes! Python venv…!
You chose one of the advanced installation methods that is normally used by users who are already familiar with the technique of installing and maintaining python applications in a virtual environment.
hajo62
(Hajo)
March 22, 2022, 7:09pm
8
Go with docker i.e. on an ubuntu OS…
Update is totally easy in such an environment.
just
docker-compose pull homeassistant
docker-compose stop homeassistant
docker-compose up -d homeassistant
mfx
(mfx)
March 22, 2022, 7:11pm
9
is there a supervisor? I feel like my HA is missing like all the good features but maybe that‘s only a feeling.
mfx
(mfx)
March 22, 2022, 7:16pm
10
Cmdline says I‘m on 2022.3. Website says it‘s Home Assistant 2021.3.2 … weird, right?
pip3 install --upgrade homeassistantLooking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: homeassistant in /srv/homeassistant/lib/python3.9/site-packages (2022.3.6)
Requirement already satisfied: jinja2==3.0.3 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (3.0.3)
Requirement already satisfied: PyJWT==2.1.0 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (2.1.0)
Requirement already satisfied: cryptography==35.0.0 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (35.0.0)
Requirement already satisfied: typing-extensions<5.0,>=3.10.0.2 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (4.1.1)
Requirement already satisfied: awesomeversion==22.2.0 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (22.2.0)
Requirement already satisfied: httpx==0.21.3 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (0.21.3)
Requirement already satisfied: atomicwrites==1.4.0 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (1.4.0)
Requirement already satisfied: voluptuous-serialize==2.5.0 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (2.5.0)
Requirement already satisfied: requests==2.27.1 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (2.27.1)
Requirement already satisfied: certifi>=2021.5.30 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (2021.10.8)
Requirement already satisfied: pyyaml==6.0 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (6.0)
Requirement already satisfied: yarl==1.7.2 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (1.7.2)
Requirement already satisfied: ciso8601==2.2.0 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (2.2.0)
Requirement already satisfied: bcrypt==3.1.7 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (3.1.7)
Requirement already satisfied: python-slugify==4.0.1 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (4.0.1)
Requirement already satisfied: attrs==21.2.0 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (21.2.0)
Requirement already satisfied: astral==2.2 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (2.2)
Requirement already satisfied: pip<22.1,>=21.0 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (22.0.4)
Requirement already satisfied: aiohttp==3.8.1 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (3.8.1)
Requirement already satisfied: ifaddr==0.1.7 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (0.1.7)
Requirement already satisfied: async-timeout==4.0.2 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (4.0.2)
Requirement already satisfied: voluptuous==0.12.2 in /srv/homeassistant/lib/python3.9/site-packages (from homeassistant) (0.12.2)
Requirement already satisfied: charset-normalizer<3.0,>=2.0 in /srv/homeassistant/lib/python3.9/site-packages (from aiohttp==3.8.1->homeassistant) (2.0.12)
Requirement already satisfied: frozenlist>=1.1.1 in /srv/homeassistant/lib/python3.9/site-packages (from aiohttp==3.8.1->homeassistant) (1.3.0)
Requirement already satisfied: aiosignal>=1.1.2 in /srv/homeassistant/lib/python3.9/site-packages (from aiohttp==3.8.1->homeassistant) (1.2.0)
Requirement already satisfied: multidict<7.0,>=4.5 in /srv/homeassistant/lib/python3.9/site-packages (from aiohttp==3.8.1->homeassistant) (5.1.0)
Requirement already satisfied: pytz in /srv/homeassistant/lib/python3.9/site-packages (from astral==2.2->homeassistant) (2021.1)
Requirement already satisfied: six>=1.4.1 in /srv/homeassistant/lib/python3.9/site-packages (from bcrypt==3.1.7->homeassistant) (1.15.0)
Requirement already satisfied: cffi>=1.1 in /srv/homeassistant/lib/python3.9/site-packages (from bcrypt==3.1.7->homeassistant) (1.14.5)
Requirement already satisfied: sniffio in /srv/homeassistant/lib/python3.9/site-packages (from httpx==0.21.3->homeassistant) (1.2.0)
Requirement already satisfied: httpcore<0.15.0,>=0.14.0 in /srv/homeassistant/lib/python3.9/site-packages (from httpx==0.21.3->homeassistant) (0.14.7)
Requirement already satisfied: rfc3986[idna2008]<2,>=1.3 in /srv/homeassistant/lib/python3.9/site-packages (from httpx==0.21.3->homeassistant) (1.4.0)
Requirement already satisfied: MarkupSafe>=2.0 in /srv/homeassistant/lib/python3.9/site-packages (from jinja2==3.0.3->homeassistant) (2.1.1)
Requirement already satisfied: text-unidecode>=1.3 in /srv/homeassistant/lib/python3.9/site-packages (from python-slugify==4.0.1->homeassistant) (1.3)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /srv/homeassistant/lib/python3.9/site-packages (from requests==2.27.1->homeassistant) (1.26.3)
Requirement already satisfied: idna<4,>=2.5 in /srv/homeassistant/lib/python3.9/site-packages (from requests==2.27.1->homeassistant) (2.10)
Requirement already satisfied: pycparser in /srv/homeassistant/lib/python3.9/site-packages (from cffi>=1.1->bcrypt==3.1.7->homeassistant) (2.20)
Requirement already satisfied: anyio==3.* in /srv/homeassistant/lib/python3.9/site-packages (from httpcore<0.15.0,>=0.14.0->httpx==0.21.3->homeassistant) (3.5.0)
Requirement already satisfied: h11<0.13,>=0.11 in /srv/homeassistant/lib/python3.9/site-packages (from httpcore<0.15.0,>=0.14.0->httpx==0.21.3->homeassistant) (0.12.0)
123
(Taras)
11
finity
March 22, 2022, 7:19pm
12
You can run HA Supervised on your own OS but it’s usually not recommended because there are potential pitfalls (unsupported or unhealthy system that prevents you from ever updating).
if you want to run your own OS then the only real viable option (aside from what you already have) is to run HA Container. But again you won’t have the Supervisor.
I run HA Container (with no Supervisor) and I don’t feel I’m missing anything at all. I still have my own OS and I just handle all of the HA stuff myself. And updates in Docker are a breeze.
mfx
(mfx)
March 22, 2022, 7:21pm
13
hmm… my screenshot says I‘m running container as well? Container = docker? …edit… oh last line… says docker yes … so basically I‘m running HA twice! Great!! Haha… oh jeez… can‘t get more confusing at this point.
mfx
(mfx)
March 22, 2022, 7:28pm
14
not so easy as it reads
sudo docker-compose pull homeassistant
ERROR:
Can't find a suitable configuration file in this directory or any
parent. Are you in the right directory?
Supported filenames: docker-compose.yml, docker-compose.yaml
finity
15
well, yes it does. So you already have my recommended way of running HA.
mfx:
Container = docker?
yes.
I also recommend you run an app (in Docker) called Portainer.
it simplifies a lot of the maintenance you need to do.
But Docker by itself is sufficient.
mfx
(mfx)
March 22, 2022, 7:30pm
16
Portainer? Aha…? Sounds good! I will do my research!
hajo62
(Hajo)
March 22, 2022, 7:31pm
17
mfx:
New to docker? - Basic knowledge of docker and docker compose is useful.
You need a docker-compose.yaml
-file with some definitions. Can share mine, but as I wrote - some minimal knowledge…
version: '3.8'
services:
# Homeassistant
homeassistant:
container_name: homeassistant
image: homeassistant/raspberrypi4-homeassistant:stable
depends_on:
- HA-mariadb
deploy:
resources:
limits:
memory: 2048M
volumes:
- /home/hajo/docker-volumes/homeassistant:/config
- /etc/localtime:/etc/localtime:ro
expose:
- "8123"
ports:
- "8123:8123"
restart: unless-stopped
network_mode: host
# Homeassistant - Datenbank
HA-mariadb:
image: mariadb
container_name: HA-mariadb
volumes:
- /home/hajo/docker-volumes/homeassistant-mariadb:/var/lib/mysql
#- /tmp/mariadb:/var/lib/mysql
environment:
TZ: Europe/Berlin
MYSQL_ROOT_PASSWORD: "${MYSQL_ROOT_PASSWORD}"
MYSQL_USER: ${MYSQL_USER}
MYSQL_PASSWORD: "${MYSQL_PASSWORD}"
MYSQL_DATABASE: ${MYSQL_DATABASE}
ports:
- 3306:3306
healthcheck:
test: mysqladmin ping -h 127.0.0.1 -u root --password=$MYSQL_ROOT_PASSWORD || exit 1
interval: 30s
timeout: 5s
retries: 5
The docker-compose
command needs to be run from the dir, where the docker-compose.yaml
is stored…
mfx
(mfx)
March 22, 2022, 7:33pm
18
haha… yeah… I thought venv were quite complicated (to remember how to get in there)… since I‘m running HA in docker I guess I only need to find / remember the correct folder hidden somewhere with that file? (/srv/homeassistant I suppose? But I have no clue what to do with your compose.yaml… 100 things I wouldn‘t know … mariadb password?! no clue, man!)
I have to say… I want to switch back to venv - way easier!
ah… /docker/ is the path for my yaml … good to have a better memory called bash_history
mfx
(mfx)
March 22, 2022, 8:28pm
19
Okay… I ran all those three commands successfully! But now no webGUI anymore … hmm … do I have to do anything else?
docker-compose logs --tail 100 -f homeassistant
Attaching to home-assistant
home-assistant | [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
home-assistant | [s6-init] ensuring user provided files have correct perms...exited 0.
home-assistant | [fix-attrs.d] applying ownership & permissions fixes...
home-assistant | [fix-attrs.d] done.
home-assistant | [cont-init.d] executing container initialization scripts...
home-assistant | [cont-init.d] done.
home-assistant | [services.d] starting services
home-assistant | [services.d] done.
home-assistant | Fatal Python error: init_interp_main: can't initialize time
home-assistant | Python runtime state: core initialized
home-assistant | PermissionError: [Errno 1] Operation not permitted
home-assistant |
home-assistant | Current thread 0x76f09020 (most recent call first):
home-assistant | <no Python frame>
home-assistant | [finish] process exit code 1
home-assistant | [cont-finish.d] executing container finish scripts...
home-assistant | [cont-finish.d] done.
home-assistant | [s6-finish] waiting for services.
home-assistant | [s6-finish] sending all processes the TERM signal.
home-assistant | [s6-finish] sending all processes the KILL signal and exiting.
home-assistant |
home-assistant | Current thread 0x76f0b020 (most recent call first):
home-assistant |
home-assistant | Current thread 0x76f22020 (most recent call first):
home-assistant |
home-assistant | Current thread 0x76f88020 (most recent call first):
home-assistant |
home-assistant | Current thread 0x76fcd020 (most recent call first):
home-assistant exited with code 1
using docker --version
Docker version 20.10.5, build 55c4c88
…can‘t make any new postings because I‘m new to this forum.
Trying sudo apt upgrade now and hope it‘ll fix it.
Edit 2:
It now works …after updating manually this libseccomp2. What a ride!
nickrout
(Nick Rout)
March 22, 2022, 8:39pm
20
Slow down. In the space of 2 hours you have changed install methods, updated versions, set up docker-compose. Slow down.
The docker commands to setup and update ha via docker are here
Now that is a raspberry pi page, and we don’t know your setup, but the commands are the same on any platform running Docker and using the container installation method.
Slow down, and if a problem arises, ask. Don’t go further down a rabbit hole with commands you don’t understand.
