How to upgrade from 10.0.rc3 to 10.0.rc4?
I just recently switched from running HA Supervised to HAOS. I installed 10.0.rc3, and now I want to upgrade to rc4. How do I do this? Can this be done from the web UI (or from the SSH client in the UI), or do I need to connect a keyboard and monitor to my machine and do it from the terminal?
If you are part of the beta channel it should appear as an available update. You can enable/join beta channel by clicking on the 3 dots menu at the top right on the Settings > System > Updates menu.
Thank you! rc4 did show up as an upgrade once I joined the beta channel, and the upgrade seems to have worked without issues.
