How to upgrade Hassbian to Stretch
I would like to upgrade Hassbian to Stretch, but I don’t know how to do it correctly.
Should I do this?
sudo hassbian-config upgrade hassbian
Or this?
sudo apt-get -y upgrade
Or neither of them?
This is what I did to update my hassbian to Stretch before I upgraded my Python version to the required version several months ago;
$ sudo apt-get update
$ sudo apt-get upgrade
$ sudo apt-get dist-upgrade
$ sudo sed -i 's/jessie/stretch/g' /etc/apt/sources.list
$ sudo reboot
I think that is all the steps. I wrote then down at the time I did it so I’m pretty sure it’s complete
I followed these instructions here - worked a treat:
http://baddotrobot.com/blog/2017/10/26/upgrade-raspian-jessie-to-stretch/
If I remember correctly, the this extra step was required:
Run the sed command for each.
Thank you. When I update to stretch, do I need to do anything with home assistant? Or it will just work without any problem?
Just make sure you backup your /config folder and then worst case you just re-image the SD-Card. In your position I would do that instead of upgrading anyway.
Of course, I’ll create an sd-card image :slight_smile:
I’m just asking if some of you did the update, and can confirm if HA it’s working correctly or not :slight_smile:
EDIT: As I read in other post, it seems that remove the old virtual environment and create a new one is required, right?:
The virtual environment defined which version of Python to use.
If you update to stretch you get a new version of Python, so you need to create a new virtual environment to use the new version of Python.
