How to upgrade virtualenv (virtual environment) to Python 3.7 on Ubuntu ( Ubuntu server 18.04 )
So I have a home assistant installed in a virtual environment. Just upgraded python to 3.7 and want to share my experience
First thing you need to install python 3.7
sudo apt update
sudo apt install software-properties-common
sudo add-apt-repository ppa:deadsnakes/ppa
sudo apt install python3.7
sudo apt install python3.7-dev
sudo apt install python3.7-venv
Then update virtual environment
I am originally I installed virtual environment in /home/ha like this:
python3 -m venv homeassistant
So my virtual environment located in /home/ha/homeassistant You, of cause, will need to replace my path by yours.
Change directory to one level above your current virtual environment
cd /home/ha
Backup existing installation to be able to go back if something goes wrong
mv homeassistant homeassistant_bkp
Create a new virtual environment
python3.7 -m venv homeassistant
cd homeassistant
source bin/activate
pip install --upgrade pip
python3.7 -m pip install mysqlclient
python3.7 -m pip install homeassistant
You will need to install any additional packages you are using. In my example, as you can see, I am installing mysqlclient. If you don’t use mysql you don’t need to install it.
Finally, it is currently some bug causing missing frontend package. So, for now, you will need to install it manually:
pip install home-assistant-frontend
That is all. You can run HA as usually after this.
I myself went through this yesterday on a couple of Ubuntu systems.
On 16.04 you need deadsnake ppa, but on 18.04 you don’t have to use deadsnake as 3.7.3 is available on Ubuntu’s regular upstream.
Just for regular people. When you saying ā€œ3.7.3 is available on Ubuntu’s regular upstreamā€ you mean
Will install python3.7.3 without adding deadsnake ppa? :slight_smile:
Yes (no ppa)! This is what I did on my 18.04 yesterday:
$ sudo apt install python3.7
$ sudo apt install python3.7-venv
and from my virtual environment:
python3 --version
Python 3.7.3
Ok. Good to know. Thanks.
Did you get the missing front-end part ?
Yes unfortunately :frowning: . but found a way to get it to work :slight_smile:
Run (within the venv) pip install home-assistant-frontend
That was the bit I was missing, last python upgrade i just started a new container and moved my configs over.
:joy:
I was on 3.6, but wanted to upgrade to v0.101. I said, ā€˜Screw it’, and went right to 3.8.
Thanks for this. Having the same missing front-end issue on FreeNAS. Installing it manually gets everything working again!
Thank you very much for this. Looks like I’m going to need to upgrade as well. As comfortable as I generally feel in HA, I don’t feel as comfortable in unix. I can install, download updates, follow instructions, etc.
I did my install about a year ago using these instructions
venv
(as another user)
So, if I generally follow your instructions I will have to do some steps as the Home Assistant User, right?
EDIT: Couple of questions
So If I did this
sudo -u homeassistant -H -s
cd /srv/homeassistant
python3 -m venv .
source bin/activate
when I did my initial install, what folder do I need to backup (mv) to be safe?
/srv/homeassistant ?
Also, I think that this is what I’d do to upgrade if I’m running VENV as another user
sudo apt update
cd /srv
sudo mkdir homeassistant (might not be needed, depends on path to previous install?)
sudo chown homeassistant:homeassistant homeassistant (might not be needed, depends on path to previous install?)
python3.7 -m venv .
source bin/activate
pip install --upgrade pip (not sure if needed??)
Does that look right?
As I mentioned in my earlier post, if you have Ubuntu 18.x you can skip deadsnakes (lines 1 - 3).
I recommend you first update you system in general:
sudo apt update
sudo apt upgrade
If you want to use deadsnakes do lines 2, 3 and then 1.
The rest looks about right. Just note that once you have run source bin/activate, then your command line interface has been setup to automatically use python3.7 meaning you don’t have to specify 3.7 in any more of your commands (unless you run deactivate), so you would only need to enter pip install homeassistant.
All,
Thanks for this. I am using HA on ubuntu 18.04 installed in a virtual environment as user ā€˜homeassistant’. my config files are in /home/homeassistant/.homeassistant and i use an external mySQL database.
Below are the exact steps I took to install (I can take no credit for it as it is all the bits in the posts above put together!):
systemctl stop home-assistant@homeassistant
apt update
cd /srv
#cp homeassistant homeassistant_old ##edited below as it should be a mv
mv homeassistant homeassistant_old
mkdir homeassistant
python3.7 -m venv .
source bin/activate
exit
systemctl start home-assistant@homeassistant
journalctl -f -u home-assistant@homeassistant
I do log on as root so no sudo required.
Thanks for all the posts above that got me to this and I hope this helps anyone else with a standard Ubuntu install as user homeassistant in a virtenv
mb
Just one Quick question, did you do a
or
I agree that is what I would expect, I was just asking because in @markbajaj steps he listed cp vs mv. Figured if it was a typo he could fix his post to save others from messing up. or maybe he did do a cp, although, I’d expect that not to work. haha
You are correct, I did a mv not a copy :slight_smile:
I’ll edit the post now :+1:
mb
Thanks for this great tutorial. Does anyone have similar instructions for CentOS or a similar rpm-based linux? I previously posted about the problem with deprecating Python 3.6 for CentOS, as there are no officially supported 3.7+ packages available yet, but no one has commented yet (see Python support on CentOS after version 3.6 deprecation).
Maybe check out this thread and this comment in particular which give you some ideas how to build from scratch:
I was dreading the upgrade and thanks to your hard work it was a breeze. Thank you.
