Wanted to share this with you because it worked fine for me:
All credits go to @pnuding.
At first i tried an ESP-03 because it would have been tiny enough to be put into the case as well as the buck converter (MP2307) but I wasn’t able to solder it properly, so i took a wemos d1 mini.
I only had to cut the mounting a bit to hide it completely above the detector.
hello sir
nice work and thanks for the info sharing
have you noticed any problems from this device since you have installed it?
this would help me a lot thank you so much
