In case this helps anyone, I managed to get it sorted. See my Node Red code below:
[{"id":"82c03a3e.979678","type":"server-state-changed","z":"a91746a.8c7e7b8","name":"Bth PIR","server":"ae812271.6043b","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.ds_bathrm_motion_419","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":70,"y":360,"wires":[["eb41de2f.c365e","bfd9d8be.aa4498","aaf7090f.044778","2abb1272.ae855e"],["2abb1272.ae855e","aaf7090f.044778","eb41de2f.c365e"]]},{"id":"eb41de2f.c365e","type":"debug","z":"a91746a.8c7e7b8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":110,"y":240,"wires":[]},{"id":"bfd9d8be.aa4498","type":"api-call-service","z":"a91746a.8c7e7b8","name":"Bathrm Light On","server":"ae812271.6043b","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"{{flow.var_light}}","data":"{\"rgb_color\": [235, 164, 52], \"brightness_pct\": 80}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":360,"y":240,"wires":[[]]},{"id":"2abb1272.ae855e","type":"trigger","z":"a91746a.8c7e7b8","name":"","op1":"","op2":"off","op1type":"nul","op2type":"str","duration":"10","extend":false,"overrideDelay":false,"units":"min","reset":"on","bytopic":"all","topic":"topic","outputs":1,"x":110,"y":500,"wires":[["4dd0577.06fbaa8"]]},{"id":"412dbb4a.ce4214","type":"api-call-service","z":"a91746a.8c7e7b8","name":"Bathrm Light Off","server":"ae812271.6043b","version":1,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"{{flow.var_light}}","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":600,"y":480,"wires":[[]]},{"id":"a9de754b.734468","type":"inject","z":"a91746a.8c7e7b8","d":true,"name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"on","payloadType":"str","x":690,"y":60,"wires":[["aaf7090f.044778"]]},{"id":"aaf7090f.044778","type":"switch","z":"a91746a.8c7e7b8","name":"on off","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":310,"y":380,"wires":[["369736da.a96e3a"],[]]},{"id":"748d8377.9ec5fc","type":"switch","z":"a91746a.8c7e7b8","name":"Is It Playing","property":"state","propertyType":"msg","rules":[{"t":"eq","v":"playing","vt":"str"},{"t":"neq","v":"playing","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":650,"y":340,"wires":[[],["dd0f7ce.673358"]]},{"id":"9abc6c41.8e22","type":"better-sonos-control","z":"a91746a.8c7e7b8","confignode":"717e13e9.a8d4ac","name":"Pause Sonos bath","mode":"pause","track":"","volume":"","volume_value":"","x":630,"y":540,"wires":[]},{"id":"dd0f7ce.673358","type":"delay","z":"a91746a.8c7e7b8","name":"delay 500ms","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":870,"y":340,"wires":[["1cf6ca5c.034e76"]]},{"id":"1cf6ca5c.034e76","type":"api-call-service","z":"a91746a.8c7e7b8","name":"Get Tunes","server":"ae812271.6043b","version":1,"debugenabled":false,"service_domain":"media_player","service":"select_source","entityId":"{{flow.var_play}}","data":"{\"source\":\"{{var_tunes}}\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":870,"y":380,"wires":[["3ef5cc60.68fce4"]]},{"id":"3ef5cc60.68fce4","type":"delay","z":"a91746a.8c7e7b8","name":"delay 500ms","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1210,"y":380,"wires":[["db41db90.577798"]]},{"id":"cad9b7d1.ea67f8","type":"api-call-service","z":"a91746a.8c7e7b8","name":"Play tunes","server":"ae812271.6043b","version":1,"debugenabled":false,"service_domain":"media_player","service":"media_play","entityId":"{{flow.var_play}}","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":870,"y":500,"wires":[["fec7599b.129b98","bc6f083.e0a2df8"]]},{"id":"db41db90.577798","type":"api-call-service","z":"a91746a.8c7e7b8","name":"Shuffle Tunes","server":"ae812271.6043b","version":1,"debugenabled":false,"service_domain":"media_player","service":"shuffle_set","entityId":"{{flow.var_play}}","data":"{\"shuffle\": \"true\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":880,"y":440,"wires":[["2042ee5d.8d7702"]]},{"id":"2042ee5d.8d7702","type":"delay","z":"a91746a.8c7e7b8","name":"delay 500ms","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1210,"y":440,"wires":[["cad9b7d1.ea67f8"]]},{"id":"fec7599b.129b98","type":"debug","z":"a91746a.8c7e7b8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1210,"y":560,"wires":[]},{"id":"bc6f083.e0a2df8","type":"better-sonos-status","z":"a91746a.8c7e7b8","confignode":"717e13e9.a8d4ac","name":"Bathroom","x":1200,"y":500,"wires":[[]]},{"id":"369736da.a96e3a","type":"better-sonos-status","z":"a91746a.8c7e7b8","confignode":"717e13e9.a8d4ac","name":"Bathroom","x":500,"y":380,"wires":[["748d8377.9ec5fc"]]},{"id":"dcb532d6.248ba","type":"comment","z":"a91746a.8c7e7b8","name":"Entity Variables","info":"","x":120,"y":40,"wires":[]},{"id":"9142b244.80d8c","type":"inject","z":"a91746a.8c7e7b8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":130,"y":100,"wires":[["9576f2e7.5b87f"]]},{"id":"9576f2e7.5b87f","type":"change","z":"a91746a.8c7e7b8","name":"ENTITY VARIABLES","rules":[{"t":"set","p":"var_play","pt":"flow","to":"media_player.bathroom","tot":"str"},{"t":"set","p":"var_light","pt":"flow","to":"light.ds_bathroom_strip","tot":"str"},{"t":"set","p":"var_tunes","pt":"flow","to":"BigMix2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":100,"wires":[[]]},{"id":"f949c50e.21d018","type":"comment","z":"a91746a.8c7e7b8","name":"Lights and Music","info":"SWITCHED OFF RUNNING ON PI4 as test","x":120,"y":200,"wires":[]},{"id":"b2782215.93d1","type":"server-events","z":"a91746a.8c7e7b8","name":"HueEvent","server":"2993e8b4.fc1e78","event_type":"hue_event","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"waitForRunning":true,"x":120,"y":800,"wires":[["7645273c.0a12c8"]]},{"id":"7645273c.0a12c8","type":"switch","z":"a91746a.8c7e7b8","name":"Device","property":"payload.event.id","propertyType":"msg","rules":[{"t":"eq","v":"study_switch","vt":"str"},{"t":"eq","v":"ds_bathroom_switch","vt":"str"},{"t":"eq","v":"lounge_switch","vt":"str"},{"t":"eq","v":"kitchen_switch","vt":"str"}],"checkall":"true","repair":false,"outputs":4,"x":290,"y":800,"wires":[[],["2ab287dd.f50f58"],[],[]]},{"id":"2ab287dd.f50f58","type":"switch","z":"a91746a.8c7e7b8","name":"Bath Button","property":"payload.event.event","propertyType":"msg","rules":[{"t":"eq","v":"1003","vt":"num"},{"t":"eq","v":"2003","vt":"num"},{"t":"eq","v":"3003","vt":"num"},{"t":"eq","v":"1002","vt":"num"},{"t":"eq","v":"4002","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":490,"y":780,"wires":[[],[],[],["1192f09b.b9691f"],["55315edc.cd36b"]]},{"id":"1192f09b.b9691f","type":"api-call-service","z":"a91746a.8c7e7b8","name":"Override On","server":"ae812271.6043b","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_on","entityId":"input_boolean.bathroom_override","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":710,"y":780,"wires":[[]]},{"id":"55315edc.cd36b","type":"api-call-service","z":"a91746a.8c7e7b8","name":"Override Off","server":"ae812271.6043b","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.bathroom_override","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":710,"y":840,"wires":[[]]},{"id":"e544ad43.e8fdd","type":"comment","z":"a91746a.8c7e7b8","name":"PIR Override on HUE button ","info":"SWITCHED OFF RUNNING ON PI4 as test","x":160,"y":720,"wires":[]},{"id":"4dd0577.06fbaa8","type":"api-current-state","z":"a91746a.8c7e7b8","name":"Chrck Override","server":"ae812271.6043b","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_boolean.bathroom_override","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":320,"y":500,"wires":[["412dbb4a.ce4214","9abc6c41.8e22"],["fccef05b.f0052"]]},{"id":"fccef05b.f0052","type":"delay","z":"a91746a.8c7e7b8","name":"delay 2hrs","pauseType":"delay","timeout":"2","timeoutUnits":"hours","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":410,"y":620,"wires":[["412dbb4a.ce4214","9abc6c41.8e22","114978a5.fb9c87"]]},{"id":"114978a5.fb9c87","type":"api-call-service","z":"a91746a.8c7e7b8","name":"Override_OFF","server":"ae812271.6043b","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.bathroom_override","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":620,"y":620,"wires":[[]]},{"id":"ae812271.6043b","type":"server","name":"Home Assistant"},{"id":"717e13e9.a8d4ac","type":"better-sonos-config","name":"Bathroom","serialnum":"00-0E-58-11-34-BE:7","ipaddress":"192.168.1.223"},{"id":"2993e8b4.fc1e78","type":"server","name":"Home Assistant","addon":true}]
Thanks guys!
