How to use a templated title in an Markdown Card?
Here is my question : I try to put a title to a horizontal stack. Maybe a picture would be clearer :
Capture d’écran du 2023-10-22 20-32-39
So I tried this code (But, as you can see, the result is not what I expected) :
title: " {{ area_name('sensor.temp_hum_1_temperature') }} "
cards:
  - type: custom:mini-graph-card
    entities:
      - sensor.temp_hum_1_temperature
    line_color: '#e16366'
    icon: mdi:tree
    line_width: 8
    font_size: 75
    unit: °C
    entities:
      - sensor.temp_hum_1_humidity
    line_color: '#4e93dd'
    icon: mdi:wave
    line_width: 8
    font_size: 75
    unit: °C
I asked in the mini-graph github and thanks to ildar170975 I understood my issue is using a templated title in an horizontal-stack card.
My first research leads me to this post :https://community.home-assistant.io/t/templates-for-horizontal-stack/153854
I hadn’t the time to try this solution. If someone could confirm I’m going the right direction, you’re welcome :slight_smile:
you can use Custom:mushroom-card, available in HACS
type: custom:mushroom-title-card
title: Hello, {{ user }} !!!
How ever your biggest challenge is to learn to write a template :slight_smile: , have you tested your “template” in the Template-Editor ?
Here is another example for mushroom-title-card
title: 'The Sun is {{ states(''sun.sun'') }}'
PS: Various cards have “some twists” in how they want/interpret templates
The thread’s title “template in mini-graph-card” is wrong, you admitted yourself that this a stack card’s title.
A possible solution could be using a standard Markdown card placed in a vertical stack with your horizontal stack. Markdown supports templates and may be styled (font size) to mimic a card’s title.
No, this is about defining cards inside a stack. You need to define a title only.
Thanks a lot for all the answers.
First : I modified the title of my post, to be clearer.
Then, as I come from Domoticz and am a total beginner in HA, I carefully read your messages and tried to make all the pieces match.
And hopefully, it worked as I wanted:
Capture d’écran du 2023-10-23 19-21-12
cards:
 - type: markdown
   content: |
 - type: horizontal-stack
   cards:
       entities:
       icon: mdi:tree
       line_width: 8
       font_size: 75
       unit: °C
       entities:
       icon: mdi:wave
       line_width: 8
       font_size: 75
       unit: '%'
Thanks to you, I think I now understand what is a card, how to mix them and what are markdown cards. I’m still struggling to perfectly understand how to write templates, but I hope to be in the right direction.
So am i, and it doesn’t help with all “variations” i.e mushroom-cards and custom-button-cards, beside card-mod :slight_smile:
Btw, in markdown-card you Center the Text with these “tags”
`content: <center>{{ area_name('sensor.temp_hum_1_temperature') }}</center>`
And you are right in your approach of using i.e nested-stacks , i.e a vertical for the entities/cards “belonging to each other” , then you can have horizontal/vertical stacks/cards inside the initial vertical stack etc.
Uses JS.
Uses jinja w/o any issues. Means - same results in “Dev tools - Template” and in a card.
Yes, i knew very little JS when i started with HA, and never heard about jinja Nor Yaml :slight_smile:
My best(but old) knowledge was html, css
You are welcome, I am from QNX + C + Fortran + asm from 1995, never dealt with css & html )
