How to use a variable in a script, when using a template
I have more or less the same question.
My automation is starting a script, and passing some variables:
      - service: script.turn_on
          entity_id:
            - script.google_location
          variables:
            worksheet: 'GLocPerson'
            devicetracker: 'device_tracker.life360_familymember1'
            person: 'person.person1'
            sensor: 'sensor.life360_member_adres'
My script (that isn’t working because I don’t know exactly how to use the variables correctly):
  google_location:
    sequence:
      - service: google_sheets.append_sheet
          config_entry: cx5xax2xbb75dfxb19c51fbo
          worksheet: "{{ worksheet }}"
            address: "{{ state_attr('}}{{ devicetracker }}{{','address') }}"
            last_seen: "{{ state_attr('}}{{ devicetracker }}{{','last_seen') }}"
            latitude: "{{ state_attr('}}{{ devicetracker }}{{','latitude') }}"
            longitude: "{{ state_attr('}}{{ devicetracker }}{{','longitude') }}"
            gps_accuracy: "{{ state_attr('}}{{ devicetracker }}{{','gps_accuracy') }}"
            zone: "{{ states('}}{{ person }}{{') }}"
            address2: "{{ states('}}{{ sensor }}{{') }}"
            place: "{{ state_attr('}}{{ devicetracker }}{{','place') }}"
            speed: "{{ state_attr('}}{{ devicetracker }}{{','speed') | round(0) }}"
    mode: queued
I also tried it like this:
address: "{{ state_attr('{{ devicetracker }}','address') }}"
What i’m I doing wrong ?
Like this:
            address: "{{ state_attr(devicetracker,'address') }}"
You are already inside the template braces {{ }} there’s no need to uses them again to access your variables.
