I have d1mini board soldered using all pins. I would like to use any remaining - looking on
I would like to use GPIO16 GPIO1 GPIO0 which has some strange labels on image, and doesn’t work when I have tried to use it.
This is bathroom fan / light controller with temperature measurement on i2c and 2 hardware buttons.
So, I am using pins:
GPIO12
GPIO13
GPIO14
GPIO15
GPIO2
GPIO3
GPIO4
GPIO5
When I have tried to use GPIO0 connected sensor/relays blocks start of the board. To restart the board I have had unplug that pin and manually restart board.
Currently I am not sure about behaviour on using GPIO1 (TX) pin, but connecting switch - binary_sensor here also doesn’t work (or been blocking start).
How can I use GPIO1, GPIO0 and GPIO16 pins?
Below my code
i2c:
- sda: GPIO4
scl: GPIO5
- platform: htu21d
temperature:
humidity:
update_interval: 1s
web_server:
port: 80
switch:
- platform: gpio
pin: GPIO15 #D8
- platform: gpio
pin: GPIO13 #D7
- platform: gpio
pin: GPIO12 #D6
- platform: gpio
pin: GPIO14 #D5
binary_sensor:
- platform: gpio
pin: GPIO3 #GPIO2
device_class: window
on_state:
then:
- switch.toggle: IN2
- platform: gpio
pin: GPIO2 #GPIO0
on_press:
then:
- switch.toggle: IN3
Thanks in advance for any help
regards
. I use d1 of the D1
